FPU CFLAGS for ARM1176
by cnxsoft » Fri Jan 27, 2012 3:05 pm
I'm compiling some program where I would like to enable the FPU.
I'm now trying the program in qemu with ARM1176. I'm using Emdebian toolchain, but I guess the flags should be the same for all cross-compilers.
In the emulator if I use:
CFLAGS="-march=armv6 -mfpu=vfp -mfloat-abi=softfp"
The program will exit with "illegal instruction". Even a simple "hello world" type program accessing to float will crash.
if i use CFLAGS="-march=armv6 -mfpu=vfp"
It will work.
Which cflags should I use to make use of the FPU in Broadcom BCM2835 ?
by jamesh » Fri Jan 27, 2012 3:47 pm
cnxsoft said:
I"m compiling some program where I would like to enable the FPU.
I"m now trying the program in qemu with ARM1176. I"m using Emdebian toolchain, but I guess the flags should be the same for all cross-compilers.
It will work.
I think the performance section in the Wiki has the settings I used on the Alpha boards.
Volunteer at the Raspberry Pi Foundation, helper at Picademy September, October, November 2014.
by cnxsoft » Sat Jan 28, 2012 1:14 am
I could not it in the Wiki (which has changed a lot recently), but I found a forum post.  (floating point search provides better results than fpu...)
http://www.raspberrypi.org/for.....erformance
You used:
gcc -O3 -mfloat-abi=softfp
I'm also interested in hardfloat, because have seen some impressive benchmarks on pandaboard (gzip 5 to 6 times faster with hardfloat vs softfloat).
In the same forum post, it seems Redhat might do a "Fedora armv6hl build" which would be great.
by Metzelmaennchen » Mon Jul 02, 2012 7:24 pm
has anyone found a solution in the meantime?
int main()
  float f;
  f = 1.0;    // illegal instruction here
  return 0;
as soon as I specify float abi to softfp I get the illegal instructions. Something with alignment but I don't get it :(
Using memcpy it works and it also works when using a packed struct to copy to the float. But to be honest, can someone tell me why the float isn't aligned correctly?
