Can't install Samba on Raspbian
by scorp » Fri Oct 19, 2012 10:32 pm
Today I tried to install Samba and have this
pi@raspberrypi ~ $ sudo apt-get install samba
Reading package lists... Done
Building dependency tree
samba is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
Setting up samba (2:3.6.6-3) ...
[FAIL] Starting Samba daemons: nmbd failed!
invoke-rc.d: initscript samba, action "start" failed.
dpkg: error processing samba (--configure):
 subprocess installed post-installation script returned error exit status 1
 samba
E: Sub-process /usr/bin/dpkg returned an error code (1)
This is actually second attempt. First one had the same failure. I did run update&upgrade but only after trying to install samba. So after realising this mistake i removed samba, run update&upgrade then installed samba and it failed again the same way. And /etc/samba doesn't exist after installation although samba installes
by texy » Sat Oct 20, 2012 9:09 pm
I don't its just samba you need to install, so try :
sudo apt-get install samba samba-common-bin
Texy
"2.8inch TFT LCD + Touch screen" add-on boards for sale here :
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=93&t=65566
50p goes to the Foundation ;-)
by elatllat » Tue Oct 23, 2012 10:34 am
might be file system corruption due to over clocking, try it on a fresh install. (I think texy fails to understad what apt is; not dpkg)
by scorp » Tue Oct 23, 2012 12:04 pm
Unfortunately system is on HDD and few things running so I decided not to do fresh install. Better to find different solution for my task - will share files via miniDLNA, they are media files which is good. I use only 800MHz overclock. Thanks for suggestions.
by texy » Tue Oct 23, 2012 12:33 pm
elatllat wrote:might be file system corruption due to over clocking, try it on a fresh install. (I think texy fails to understad what apt is; not dpkg)
Well yeah, you could be correct. I was just following the Pi wiki on installing a NAS with samba here :
http://elinux.org/R-Pi_NAS
Texy
by scorp » Tue Oct 23, 2012 12:36 pm
Texy
Sorry, I didn't reply on your message. I did try to run both samba & samba-common-bin in one line or separately, same result :(
by NewPi » Tue Nov 06, 2012 6:45 am
Start from scratch using instructions at - http://www.megaleecher.net/Adding_External_USB_Disk_Drive_Storage_On_RasPi. These worked for me twice, last time two days ago with newest official wheezy built.
Raspberry Pi Howto, Tips, Tricks and Tools -> http://bit.ly/RPiTricks
by spannernick » Thu Oct 23, 2014 2:00 pm
I have a problem too...
I get this after typing
sudo apt-get install samba-common-bin
unable to locate package samba-common-bin
What do I need to do to sort this out..?
by RaTTuS » Thu Oct 23, 2014 2:04 pm
WARNING thread necro
what does
sudo atp-get update && sudo apt-get upgrade
say
http://www.catb.org/esr/faqs/smart-questions.html <- ask smart Questions
"That's not right, the badgers have moved the goalposts."
1QC43qbL5FySu2Pi51vGqKqxy3UiJgukSX - Prosliver FTW
