Raspi and RTL-SDR
by jdubin » Thu Jun 28, 2012 8:02 am
Well, it's not polished yet, but preliminary tests show that the Raspi has enough power to do some simple NFM software-defined radio work with RTL2832U-based DVB-T USB TV tuners.
I was able to compile rtl_fm (an optimized version of Osmocom's rtl-sdr software), which allowed the Raspi to tune a frequency (162.55 MHz, weather radio band in the US) and play it real-time. The Raspi's internal sound kept hanging, so a cheap USB audio device was used instead. The audio is choppy, but CPU usage is only around 62% - which is promising.
by sexton » Sat Jul 07, 2012 10:41 am
Was the dongle powered by the Pi or externally?
by jdubin » Sat Jul 07, 2012 2:58 pm
By the Pi. The Pi itself was powered with a 2A power supply (originally an HP Touchpad power adapter).
by benryanau » Tue Aug 14, 2012 10:18 pm
Thought ot using the Pi as a USB-IP converter and piping the feed back to a more powerful PC running an SDR app in a VM?
Would this work? You can get away from thePC's RF noise, and keep the tuner close to the antenna this way..
