HELP: Using Roxio Video Capture USB to stream video
by ndeboer » Mon Dec 03, 2012 3:33 am
Hi all,
I'm trying to use my Raspberry Pi to stream video from from a PAL camera over the network using MJPG streamer. I have successfully got MJPG streaming using a Logitech C525 USB cam but now when trying to use the Roxio Video Capture USB it isn't working.
I'm running a RPi Model B with the latest wheezy OS.
When executing mjpg_streamer it prints
i: Using V4L2 device: /dev/video0
i: Desired Resolution: 640x480
i: Frames Per Second: 5
i: Format: MJPEG
Unable to set format: 1196444237 res: 640x480
Init v4L2 failed !! exit fatal
i: init_VideoIn Failed
Hints/Suggestions?
by phl » Sun Dec 16, 2012 8:23 pm
i really dont know about the c525, but its possible that you need the option "-q 100".
it is needed for YUV devices.
i use this command line to start mjpg-streamer with my ps3 eye toy camera:
mjpg_streamer -i "/usr/lib/input_uvc.so -d /dev/video0 -q 75" -o "/usr/lib/output_http.so -p 8090"
regards, phil
