Raspbian - MPD ALSA volume control too rough
by SPGremlin » Tue Oct 23, 2012 9:32 pm
I'm using clean fresh Raspbian Wheezy image (downloaded from this site earlier this week).
Installed MPD. The volume control in MPD (through mpc or other clients) works, and is reflected to the "alsamixer" settings. The problem is, it is reflected too rough:
75% volume in MPD = 36% in ALSAMIXER = "-22.58" db gain, barely hearing sound
85% volume in MPD = 54% in ALSAMIXER = "-11.94" db gain, low sound
90% volume in MPD = 67% in ALSAMIXER = "-6.62" db gain, quite low sound
95% volume in MPD = 82% in ALSAMIXER = "-1.30" db gain, moderate sound
100% volume in MPD = 100% in ALSAMIXER = "-4.0" db gain, normal sound
The problem is, my client of choice - "MPoD" for Iphone only allows controlling MPD volume settings by 5% step, which goes far too rough, I'm left with only 2-3 steps before sound goes too low.
Does anyone here know a way to remap MPD volume on alsa volume in more smooth (linear) way?
by SPGremlin » Fri Oct 26, 2012 9:33 am
Does anybody else at least observe similar behavior? Does anybody else consider this behavior erroneous?
by jonathanmt » Tue Oct 30, 2012 12:23 pm
I had a similar problem and resolved by using a software mixer.
I just uncommented the below line in /etc/mpd.conf.
mixer_type                      "software"
by SPGremlin » Sat Nov 03, 2012 3:15 pm
Thank you! This helped.
The volume gets overall low this way (I have to put speakers hardware switch higher then usual), but this is still much better then before.
