convert bluray to h264 with avconf
by damogran » Sat Nov 03, 2012 12:27 pm
hi there,
i recently bough the vc-1 and the mpeg2 licences. now i am able to play bluray and dvd dumps with oxmplayer. however i do like the idea of shrinking the dumps a bit an convert them to h264.
so i tried to convert them with avconf with no success though. actually a simple conversion with no audio fails
avconv -i bluerayinput.mkv -vcodec libx264 -an output.mp4
    Stream #0.0(eng): Video: libx264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], q=-1--1, 24k tbn, 23.98 tbc
Stream mapping:
  Stream #0:0 -> #0:0 (h264 -> libx264)
Press ctrl-c to stop encoding
Killed   18 fps=  1 q=0.0 size=       0kB time=10000000000.00 bitrate=   0.0kbits/s
(i didn't press ctrl-c)
Anybody around here who tried to convert / shrink blu ray dumps or dvd dumps (got mine from make mkv)
thanks
damo
by damogran » Wed Mar 27, 2013 11:35 am
is this even possible? using the pi to convert VC1 to h264 in one step.
by sej7278 » Wed Mar 27, 2013 12:26 pm
i'd expect it to take days even if it were possible, and a bit pointless buying the license if you're converting to h264 anyway.
you're not assuming that transcoding would be hardware accelerated like playback is are you?
by damogran » Wed Mar 27, 2013 3:03 pm
sej7278 wrote:i'd expect it to take days even if it were possible, and a bit pointless buying the license if you're converting to h264 anyway.
true, but the whole story is to make a digital copy of a blu ray and then compress it a bit to save disk space. it feels much more safer to have copies on my RAID instead of them "not so much reliable" optical thingies. plus having a collection of movies on one device is far more like a real media center.
sej7278 wrote:you're not assuming that transcoding would be hardware accelerated like playback is are you?
of course i do, since i have no clue at all. :) well i thought, having hardware decoding and encoding would turn the pi into a magic video converter. but that's not possible?
by ghans » Tue Apr 09, 2013 12:45 pm
Well , if there is no software support , how should that work ?
You can try omxtx (the only HW accelerated transcoder ) ,
but IMHO that is more like a proof-of-concept.
ghans
