Bitcoin client running in a Raspberry Pi model B
by nono242 » Wed Jul 03, 2013 6:31 pm
Hello Everyone,
The project name is RPiBTC. The aim of this project is to run the full Bitcoin client in a low cost Raspberry Pi model B. The Raspberry Pi is inexpensive, doesn't require much power to run, and best of all, it's tiny.
I made an image of the SD card and put it on share in a Torrent:
http://www.lakoco.net/RPI_BTC_V0.1.zip.torrent
I've also put a blog online with explains how to setup the client running in the Raspberry Pi. http://rpibtc.blogspot.be/
With RPiBTC, you insure the inegrity of the bitcoin network by adding a node in the p2p network. RPiBTC can handle RPC JSON requests. In the future, the RPiBTC could hold a wallet.
If you have any remarks to do, don't hesitate.
by medisoft » Tue Dec 10, 2013 7:26 am
Hi! Can you post instructions about if there is anything special to build and run the bitcoin client in the RPI?
Or the standard code can build and run on it?
thank you!
