(Raid of) USB flash drives as storage
1 post
by JF002 » Tue Jan 22, 2013 6:12 pm
Hi!
I'm using a RasperryPi as a personnal server (web server, owncloud, opendTTD server,...).
This is for personnal use, I don't expect to have thousands of visitors on my server for now.
Currently, the only storage I have is the 8GB SD card I use for the system.
I was wondering which solution I should use...
I need :
* More storage space (I don't need hundreds of GB... ~30GB could be enough)
* Reliability (I don't want to loose the data I put in Owncloud or the web server data base..)
* Cheap
I don't need :
* very fast, performances,...
* a lot of space
I know that backups are important to avoid loosing data.
I could use
* A USB hard drive
* One or more USB Flash drive.
It seems that the USB Hard drive would be the best solution, but what do you think about using 2 USB flash drives in RAID?
I was thinkink about a RAID1 of 2 16/32Gb USB flash drive. This would consome less power, I wouldn't need to add a power supply for the HD, and I wouldn't need to worry about spinning down the hard drive,...
But I don't know how flash drives perform in RAID, if the flash memory would wear too quickly.
Can you give me your thoughts about that?
My web site : https://codingfield.com
