Ustream plugin for OpenElec, Raspbmc or XBMC
by Davespice » Wed May 23, 2012 3:12 pm
Hi guys!
Just wanted to find out if there is a Ustream plugin for OpenElec, Raspbmc or XBMC?
It would be really cool if we could watch the docking of the SpaceX rocket with the ISS on the Live ISS channel.
Raspberry Pi Foundation Employee & Forum Moderator
by frying_fish » Wed May 23, 2012 3:14 pm
a little bit of googling suggests there isn't a dedicated Ustream addon for XBMC, but I couldn't say if any other addons have ustream listed.
Any addon for XBMC should work with the versions on the RPi, but that isn't a definite.
by Davespice » Wed May 23, 2012 3:22 pm
I've just found this, this looks like it supports ustream (see the hosters folder in Source > Browse > /trunk/plugins/video/plugin.video.xstream/hosters)
http://code.google.com/p/xbmc-xstream-p ... loads/list
I'll give it a try later, in the meantime - if anyone tries it and it works please let me know! =)
by Davespice » Fri May 25, 2012 3:22 pm
I have managed to get this xStream add on installed using Raspbmc, however it doesn't seem to work very well. When I run a search, for instance, 0 results are returned and it hangs at 88% until you click cancel.
The Youtube add on works fine though, so I presume the fault lies with the add on.
My goal is to use XBMC to play Ustream feeds, so if anyone knows a way - I am all ears! =)
by futaris » Thu Jul 12, 2012 6:18 am
Livestreams plugin already has NASA HD. Of course you could modify this for other ustream sites:
http://forum.xbmc.org/showthread.php?tid=97116
<item>
<title>NASA HD</title>
<link>rtmp://flash86.ustream.tv:1935/ustreamVideo/6540154 playpath=streams/live app=ustreamVideo/6540154 swfUrl="http://cdn1.ustream.tv/swf/4/viewer.rsl.558.swf" pageUrl="http://www.nasa.gov/multimedia/nasatv/ustream.html" live=true</link>
<thumbnail>http://jkontherun.files.wordpress.com/2010/09/nasa-app-hd.png</thumbnail>
</item>
And of course the NASA plugin:
http://wiki.xbmc.org/index.php?title=Ad ... d_Vodcasts
by Oetss » Sun Jan 06, 2013 6:48 pm
Hey there,
I wonderd if anyone had this worked with the tip of @futaris
michiel
by vedekandy » Tue Jul 16, 2013 8:24 am
I know this topic is a little old, but I found it earlier today whilst trying to find a way to get UStream videos to play on my RaspBMC installation. I stumbled upon this:
https://github.com/divingmule/plugin.video.ustream
It's from the same developer as the "Livestreams" plugin, which I couldn't get to work for the life of me; but I installed this, and it seems to play (and find) most streams that I want. Though a word of advice: If you try this, be sure to change "Stream type" to "Choose" in the settings to save yourself a headache. It defaults to one specific stream type and instantly fails with it's default settings :D
Hope this helps!
