play video's from usb stick
by sandbox » Sat Feb 09, 2013 4:37 pm
Hi all,
I have installed openelec on the Raspberry pi and i want to play a movie from a usb drive, i am using a SanDisk Cruzer (1gb) with a couple of small videos on it. The problem is that i am unable to locate the drive after plugging it in. Its not showing up in /media/sd . The drive has been formatted in NTFS.
Please help. Thanks in advance.
Best,
Sandbox
by RobHenry » Sun Feb 10, 2013 12:16 am
Hi sandbox,
Not sure why you're looking in /media/sd ... have you tried looking for it through the xbmc gui?
What does the lsusb command return over ssh?
Rob
by sandbox » Sun Feb 10, 2013 9:00 am
I read on some forum post that the usb drive is mounted at /media/sd. I have tried looking through the gui but i cant find it , is there any place specific i should be looking?
Also the ssh shows the usb drive. What could be the issue?
The lsusb command returned the above...
Screen shot 2013-02-10 at 2.27.37 PM.png (17.7 KiB) Viewed 661 times
by RobHenry » Sun Feb 10, 2013 9:38 am
You are correct that the drive should be auto-mounted by xbmc.
The output of
df -h
will should you what drives are mounted and where.
If it's not there then unplug it and put it back in, then inspect what's returned by
dmesg |tail
which may give a clue as to why it is not mounting.
