Raspmc
by wbaker » Fri Dec 14, 2012 7:50 pm
I'm guessing this has been previously covered but I am new to this forum, the world of Raspberry Pi and programming.
I am trying to set my RasPi up as a raspmc but can't seem to set it up. Keep repeating the same line of code
"hub 1-1:1.0: hub_port_status failed (err = -71)"
Powering the RasP using a Samsung phone charger, wired into my router, keyboard/mouse and wifi dongle not connected and using HDMI.
Not sure what is going wrong. Could anyone point me in the correct direction?
Cheers,
Wil
by Dilligaf » Fri Dec 14, 2012 8:14 pm
Check power at the TPs, you've probably got low voltage. Check here http://elinux.org/R-Pi_Troubleshooting
by wbaker » Fri Dec 14, 2012 8:40 pm
Dilligaf wrote:Check power at the TPs, you've probably got low voltage. Check here http://elinux.org/R-Pi_Troubleshooting
Thank you. What are TPs? Can you recommend a cheap power supply?
by Dilligaf » Fri Dec 14, 2012 9:17 pm
If you bothered to read the link you would know what they are.
