Firmware
by jonshouse » Thu Nov 01, 2012 10:17 pm
The latest firmware update for 512mb support seems to break the correct playback of Hi-def H264 Mpeg/TS streams. This used to work with no problems ?
This clip played perfectly before the upgrade.
http://www.youtube.com/watch?v=JvZwCD3PGxM
by Dweeber » Thu Nov 01, 2012 10:33 pm
What is the source of the video you are playing?
Dweeber A.K.A. Kevin...
My RPI Info Pages including Current Setup - http://rpi.tnet.com
by jonshouse » Thu Nov 01, 2012 10:48 pm
Before upgrade it was package
omxplayer_0.2.3~git20121013~fb1b02d8_armhf.deb
after upgrade I tried all these versions:
-rw-r--r-- 1 root root 5207774 Oct 31 03:55 omxplayer_0.2.1~git20120930~ff1a44ee_armhf.deb
-rw-r--r-- 1 root root 5207800 Oct 31 03:53 omxplayer_0.2.2~git20121011~ff1a44ee_armhf.deb
-rw-r--r-- 1 root root 5208028 Oct 13 20:29 omxplayer_0.2.3~git20121013~fb1b02d8_armhf.deb
-rw-r--r-- 1 root root 5208140 Oct 26 00:34 omxplayer_0.2.3~git20121023~8f6692d8_armhf.deb
All on Raspian.
The clip did play correctly pre firmware upgrade, now it does not.
Also xbmc on a different Pi board now fails to play these files, again it did play they pre firmware upgrade.
Sample of the video, sorry about the slow server.
http://www.jonshouse.co.uk/download/h26 ... _sample.ts
by jonshouse » Thu Nov 01, 2012 11:01 pm
Dweeber wrote:What is the source of the video you are playing?
Raw file capture of BBC HD from DVBS2 sat card.
by captn » Thu Nov 01, 2012 11:22 pm
by jonshouse » Fri Nov 02, 2012 12:16 am
captn wrote:https://github.com/raspberrypi/firmware/issues/115 :?:
Sounds similar, especially the stutter. Thanks.
by MartenR » Sun Nov 04, 2012 3:30 pm
I am experiencing the same problem here. Also several DVB h264 ts streams at 1080i are affect the whole playback is stuttering or freezing.
I have test it with omxplayer and with vompclient, which I am currently porting.
I will try to contact the developer.
Marten
