Raspbmc is slow with high cpu usage
by marksw1 » Fri Nov 02, 2012 8:52 pm
Why is the Cpu usage always above 90% and is it causing XBMC to run slow.
Is there anything i can do to reduce this to make it run stable? :(
by walleee » Sat Nov 03, 2012 4:55 am
Are you looking at CPU usage using the GUI? If so bare In mind that the CPU is used to render that page, hence the values showing so high.
If your experiencing instability you should look at your sd card and power supply, if that doesn't help come over to the raspbmc forums...
by marksw1 » Sat Nov 03, 2012 8:12 am
I have all ready been on the forum and not found anything except something saying to disable ssh (dirty regions)?? I cannot find out how to do this can you help? I am using a Kingston 16gb class4 SD card and a iPhone charger with USB to mini USB lead.
