OpenELEC Testbuilds
766 posts   Page 9 of 31   1 ... 6, 7, 8, 9, 10, 11, 12 ... 31
by Stark007 » Tue Jun 12, 2012 9:59 pm
Inaccessible Rail wrote:
I bought a cheap remote from Amazon (£5) that basically sends keyboard presses, I used the keymapedit software here to remap some custom buttons if that's any help.
Re: My Keyboard.xml not working under Openelec Rpi -Tried this and manual edit of xml using showkey.
Summary is my keyboard.xml works on XBMC windows and Raspbmc but not in Openelec, could it be related to region settings although all seem set the same in my case?
by sraue » Tue Jun 12, 2012 10:06 pm
what for a remote you use? can you do a
cat /proc/bus/input/devices | paste
and paste the link here? what you want to change, what is workin, what not?
by Stark007 » Tue Jun 12, 2012 10:55 pm
Many thanks for your reply.
My Remote sends keypresses to a USB radio receiver. Then I adjust keymap of keyboard.xml to suit, this works under windows and raspbmc when saving keyboard.xml to userdata/keymaps.
Device output below:
I: Bus=0003 Vendor=06e7 Product=0004 Version=0100
N: Name="SIMPLE DEVICES MediaRemote USB Receiver"
P: Phys=usb-bcm2708_usb-1.2/input0
S: Sysfs=/devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input0
U: Uniq=
H: Handlers=kbd event0
B: PROP=0
B: EV=120013
B: KEY=10000 7 ff9f207a c14057ff febeffdf ffefffff ffffffff fffffffe
B: MSC=10
B: LED=1f
Keyboard.xml and detail of not working buttons noted below:
<keymap>
<global>
<keyboard>
<f12>info</f12>
<home>contextmenu</home>
<pageup>scrollup</pageup>
<hash>play</hash> not working
<forwardslash>pause</forwardslash>
<closesquarebracket>fastforward</closesquarebracket> not working - sends seek -10.00
<opensquarebracket>rewind</opensquarebracket> not working -sends seek +10.00
<period>stop</period> not working - sends seek +00.30
<f4>nextscene</f4> not working
<f3>previousscene</f3> not working
<f6>volampup</f6>
<f7>volampdown</f7>
<f9>previousmenu</f9>
<numpadtimes>nextsubtitle</numpadtimes>
<semicolon>audionextlanguage</semicolon>
<numpadplus>aspectratio</numpadplus> not working -not sure if working anyway
<numpadminus>XBMC.ActivateWindow(Home)</numpadminus>
<f10>osd</f10>
<pagedown>scrolldown</pagedown>
<end>ActivateWindow(shutdownmenu)</end>
</keyboard>
</global>
</keymap>
by normal » Wed Jun 13, 2012 1:23 am
kleedrac wrote:Just out of curiosity how many of you are overclocking, by how much, and do you actually notice a marked improvement? I love how well OpenELEC works and many thanks to sraue and others here for keeping the build updated and helping those of us who have been away from the penguin a wee bit too long :)
How do you overclock in Openelec? Doing it the regualr way causes it to not boot. Even just having a blank config.txt file in the SD card under windows makes the RPi not get past the rainbow square. Am I supposed to put the config.txt in a network share? There isn't one named System so i'm not sure where to put it. Also this is with the new loader files, with the stock loader.bin/bootcode.bin etc it goes to the Openelec logo and then black screen.
by b0x » Wed Jun 13, 2012 2:28 am
One problem I'm having is, even though I set resolution to 1280x720 in system settings, it keeps starting up at 1280x768. While this is reflected correctly in the status, under system settings it still says 1280x720, as I had left it earlier. I need to change it to some other res and then back to 1280x720 in order for it to work. Anybody else have this issue?
Was having similar issues. Had to find the mode for the right resolution and added it to config.txt in /flash
hdmi_mode=85
I used tvservice to find the right number.
Once I set that - now on each reboot it comes up with at the right resolution. Before XBMC showed the right resolution, but playing a video told a different story. 4:3 was wide screen and the 16:9 was cropped to half the screen. I had to go into Setting - Video and change it to the same resolution and then it'd work right. Said I was at what I wanted too, but obviously was not.
by LastSilmaril » Wed Jun 13, 2012 2:56 am
hdmi_mode=85
Right, so I thought of that right away and I guess I'll do it, but frankly, it seems like the setting in the UI is not checked at startup, and it should be.
by Sc0ut » Wed Jun 13, 2012 6:23 am
onetootreefor wrote:@sraue, just tried r11298 and it seems like buffer issues are getting far worse. Is there any progress on this? Anything i can do to help test?
I have the same opinion. This has to be adressed first, unfortunately I can't programm openELEC so I can just wait...
by keenan » Wed Jun 13, 2012 8:14 am
Where do you get the latest builds? Openelecs daily builds are still only at r11286
Anyone got a link?
by frying_fish » Wed Jun 13, 2012 11:36 am
keenan wrote:Where do you get the latest builds? Openelecs daily builds are still only at r11286
Anyone got a link?
Most people will be building from the git source themselves I guess, although looking at the commits after 11286 I'm not sure how much is pi specific.
by onetootreefor » Wed Jun 13, 2012 2:51 pm
Anyone got a link?
yes i and others are building from git source, very simple really if you know your way around git.
Lots of the updates are RPi specific, but they get build in updates directly from xbmc-beta commits aswell which include more stabillity for raspi, (since xbmc is trying to get RasPi out of the beta git onto the main)
by rickd » Wed Jun 13, 2012 5:52 pm
I did a build from GIT initiually, it took hours.... is there a simple guide to updating this and keeping my build up-to-date??
by rickd » Wed Jun 13, 2012 5:54 pm
Link posted in other thread that contains the releases...
http://openelec.thestateofme.com/
by t-a-s » Wed Jun 13, 2012 7:07 pm
rickd wrote:I did a build from GIT initiually, it took hours.... is there a simple guide to updating this and keeping my build up-to-date??
Not used Git Hub much in the past, but this works for me...
If you have already cloned the Git, navigate to that folder and run:
# PROJECT=RPi ARCH=arm make clean
# git pull
# PROJECT=RPi ARCH=arm make release
How long it takes to compile will depend on your computer. Once its finished you'll have a tarball in the Target folder with the new release which includes a script that automates the SD card flashing.
HTH
by sparky0815 » Thu Jun 14, 2012 6:56 am
build r11300 Images (13.06.2012) ready to download
http://www.sparky0815.de
1,1GB / 2GB / 4GB Images and files of FAT partition to update
:geek:
Twitter: @Sparky0815
Facebook Gruppe (RaspberryPi - Deutschland): http://on.fb.me/PnYE99
by Goofy » Thu Jun 14, 2012 12:40 pm
SD card performance increased from 8 to 18MB/s in the r11312 build with sdhci-bcm2708 update:
root ~ # hdparm -t /dev/mmcblk0p2
/dev/mmcblk0p2:
Timing buffered disk reads: 56 MB in 3.03 seconds = 18.49 MB/sec
GUI now reads directories with more files much faster :D
by Nodge » Thu Jun 14, 2012 12:48 pm
I've just tried r11312 and TV Series is still not showing banner and thumbnails correctly. When the TV database is first scraped the screenshots for recently added episodes showing in the main menu for TV Series are correct. Then if I down-arrow to "Title" to view the series in Big List view the banners appear correctly initially. But then if I opt to change the view to "Thumbnail" and then to "Wide Icons" things start to go wrong. The banners start to get corrupted and seem to want to display as portrait rather than landscape orientation. Then if I escape back to the main menu then the screenshots for recently added episodes are also starting to get corrupted. All releases I have tried have been like this.
I'm also finding that navigating around the menus generally is very laggy. Would a faster sd card help here - I'm using a class 4 at the moment?
by komple » Thu Jun 14, 2012 4:10 pm
Problem I have is that when I start video from XBMC my screen on TV goes mad, same thing on projector. Picture is likeout of sync moving fast. everything is fine until I play movie, or video from youtube.
I use composit output.
Anyone has idea what it can be.
Thanks,
Igor
by sparky0815 » Thu Jun 14, 2012 4:11 pm
build r11312 Images (14.06.2012) ready to download
http://sparky0815.de/category/raspberry-pi-2/openelec/
:geek:
by komple » Thu Jun 14, 2012 4:26 pm
sparky0815 wrote:build r11312 Images (14.06.2012) ready to download
:geek:
It gives message 403 Forbidden.........
by sparky0815 » Thu Jun 14, 2012 4:36 pm
:geek:
hmmm
try http://sparky0815.de/category/raspberry-pi-2/openelec/
by komple » Thu Jun 14, 2012 4:45 pm
:geek:
hmmm
that one works ... thanks.
by arqcan » Thu Jun 14, 2012 5:33 pm
Nodge wrote:I've just tried r11312 and TV Series is still not showing banner and thumbnails correctly. When the TV database is first scraped the screenshots for recently added episodes showing in the main menu for TV Series are correct. Then if I down-arrow to "Title" to view the series in Big List view the banners appear correctly initially. But then if I opt to change the view to "Thumbnail" and then to "Wide Icons" things start to go wrong. The banners start to get corrupted and seem to want to display as portrait rather than landscape orientation. Then if I escape back to the main menu then the screenshots for recently added episodes are also starting to get corrupted. All releases I have tried have been like this.
i'm having the same issue also using a class 4 card, i've tried deleting both the thumbnail folders and the textures file the only thing that might be different is that mine is reading the thumbs from a mysql database.
by sraue » Thu Jun 14, 2012 6:05 pm
Another short update (r11315):
http://sources.openelec.tv/tmp/image/op ... 15.tar.bz2
to update a older build without reinstalling: http://wiki.openelec.tv/index.php?title ... g_OpenELEC
  • updated XBMC many thanks to 'gimli'
  • SD-card updates to the kernel for faster transferrates see viewtopic.php?f=63&t=5057
  • updated CEC daemon many thanks to 'olajep'
the changes to the kernel needs updated bootloaderfiles which you can find in the build in the folder 3rdpart/bootloader. This you can update locally via Windows/Linux or via ssh:
  • login via ssh to your Raspi:
    ssh root@<ipaddress>
  • remount /flash r/w:
    mount -o remount,rw /flash
  • from your linux system copy the files via ssh/scp to the Raspi:
    scp 3rdparty/bootloader/* root@<ipaddress>:/flash
please test your SD cards, i *hope* this patch fixes some issues with not working cards too, so please test your working and not working cards and report back.
thanks
Stephan
by milhouse » Thu Jun 14, 2012 9:43 pm
sraue wrote:Hi,
SD card performance (Transcend 8GB Class 10) is better than in previous builds (I've been following the SD card thread - very interesting!). Testing with "hdparm -tT /dev/mmcblk0" (non-destructive so safe for anyone else to try!) results in the following:
Before (r 11286):
 Timing cached reads:    52 MB in  2.02 seconds =  25.77 MB/sec
 Timing buffered disk reads:  26 MB in  3.11 seconds =   8.37 MB/sec
After (r 11315):
 Timing cached reads:    66 MB in  2.05 seconds =  32.13 MB/sec
 Timing buffered disk reads:  54 MB in  3.05 seconds =  17.72 MB/sec
So double the performance - probably due to the clock doubling from 25MHz to 50MHz as the default in this new build. Excellent work all concerned! :)
One immediately obvious regression is the CPU load while the GUI is idle - it's pegged at 80% in this build, when previously it would tick over at 3-5%. All I've done is boot this build, then let it sit at the opening menu for 5 minutes but still the CPU is hammering away and I don't know why. I briefly enabled Debugging to confirm there is nothing being logged so it doesn't look as though it's busy doing work.
by milhouse » Thu Jun 14, 2012 9:52 pm
1) Probably an issue with XBMC (and I noticed this in the previous build also), but 1920x1080 fanart is displayed with a thin black bar (about 20 pixels wide or so) running vertically down the right hand side - it looks like the image has been "cropped"... 1280x720 fanart is displayed correctly (ie. uncropped, without the black bar).
2) Continuing to get NFS related errors in this build (I think mempiz might look at these next week?) - I allowed the GUI to go idle while browsing thumbnails in Movies, then resumed browsing:
22:50:35 T:1101976080  NOTICE: NFS is idle. Closing the remaining connections.
22:51:41 T:1245660256  NOTICE: Thread Jobworker start, auto delete: true
22:53:55 T:1245660256  NOTICE: Previous line repeats 3 times.
22:53:55 T:1245660256   ERROR: NFS: Failed to stat(/mnt/share/media/Video/Movies HD/The A-Team (2010)[BDRip]-fanart.jpg) stat call failed with "NFS: Lookup of //media failed with NFS3ERR_NOTDIR(-20)"
22:53:55 T:1245660256   ERROR: COMXImage::ReadFile nfs://192.168.0.3//mnt/share/media/Video/Movies HD/The A-Team (2010)[BDRip]-fanart.jpg not found
File does exist:
[root@freenas] /mnt/share/media/Video# ls -la "/mnt/share/media/Video/Movies HD/The A-Team (2010)[BDRip]-fanart.jpg"
-rw-rw-r--  1 neil  neil  335800 Jun 13 03:51 /mnt/share/media/Video/Movies HD/The A-Team (2010)[BDRip]-fanart.jpg
For some reason it has now decided to cache the fanart for "The Adventures of Tintin" against "The A-Team"... NFS failures seem to cause weird and unexpected results! :)
