file list without hidden files
by c7aig » Sat Jun 23, 2012 2:01 pm
I am using code like this to print a list of files:
folder=/home/pi/Desktop/
dirList=os.listdir(folder)
for list in dirList:
print list
This is fine but because I am often updating the folder with OSX it keeps showing up .DS_STORE files. Is there a way to exclude anything hidden (with a .)?
Craig
by SN » Sat Jun 23, 2012 2:24 pm
put an if statement inside the for loop and check the first character for a dot?
Steve N – binatone mk4->intellivision->zx81->spectrum->cbm64->cpc6128->520stfm->pc->raspi ?
by andyl » Sat Jun 23, 2012 3:14 pm
SN wrote:put an if statement inside the for loop and check the first character for a dot?
That is one way of doing it.
Better would be
def isNotHiddenFilename(fname):
    return not fname.startswith(".")
folder="/home/pi/Desktop/"
nonHiddenFiles= filter(isNotHiddenFilename, dirList)
Even better.you can use list comprehensions
nonHiddenFiles = [ filename for filename in dirList  if not filename.startsWith(".") ]
Or use filter with a lambda (which will get rid of the small function in the first example
nonHiddenFiles  = filter(lambda fname: not fname.startswith("."), dirList)
The last two are quite advanced Python though and some people find them hard to read.
by c7aig » Sat Jun 23, 2012 3:33 pm
Thanks for the detailed reply, I went with the first option which has given me exactly what I was after :)
Craig
by Joe Schmoe » Sat Jun 23, 2012 3:37 pm
So...
The answer to the question is: No, there isn't. What there are are workarounds/kludges to filter the dot files out of the list, but there's no way to have the list not contain them in the first place.
Oh, how I wish that the signature facility on this board weren't so broken.
It is broken in that every time you change your signature, all of your posts reflect the change, not just those going forward.
