Could not find terminal "xterm"
by jj2127 » Tue Jun 12, 2012 6:22 pm
I get this error whenever i try and run a basic program i make in geany. Anyone know how to fix this?
by andyl » Tue Jun 12, 2012 10:13 pm
Yep - slight problem with geany.
In the meantime choose the Edit | Properties menu item and choose tools on the left tab bar.
For terminal change xterm to be x-terminal-emulator
This will then use the default terminal emulator you have installed, and if you change it using update-alternatives it will still use your preferred terminal emulator.
Alternatively just install xterm
by jj2127 » Tue Jun 12, 2012 10:53 pm
Thanks got it working now
