matplotlib without x
by sufman » Thu Nov 29, 2012 1:46 pm
Hello all,
I am new to this forum. I am using the R-Pi to produce some graphs.
I am using matplotlb and numpy (pre installed) on Occidentallis (basically raspbian)
However I have found it works when I startx and run the python code from within the GUI. But is there a way to run it without "startx"?
Current the end of the errors I get are:
_tkinter. TclError: no display name and no $DISPLAY environment variable
note: that is not all of the errors but seems the most relevant.
Thanks for any help :D
by fdion » Thu Nov 29, 2012 6:21 pm
You can use xvfb python script.py
I posted a more detailed answer with a graph here:
http://www.raspberry-python.blogspot.com/2012/11/matplotlib-without-x-server.html
François
Francois
http://raspberry-python.blogspot.com - http://www.3dFutureTech.info - @f_dion
by sufman » Thu Dec 06, 2012 12:55 pm
Hello
Thanks for this reply, it works but what if i wanted to run the graph in real time rather than saving it using the command show()?
Thanks for all the help!
