pyhton file
by thivtulz » Thu Dec 27, 2012 1:13 am
Let's say i save a python file to the SD card.How to run the saved file using Raspberry Pi so that can get the output..
by trouch » Thu Dec 27, 2012 4:38 pm
can you be more explaining ?
how did you write your python file ?
how did you save your file on the card ?
how do you use your Pi ?
we generally use python to execute python files :
python myfile.py
you can also add an interpreter on your script first line
#!/usr/bin/python
import RPi.GPIO
then make your script executable :
chmod a+x myfile.py
WebIOPi - Raspberry Pi REST Framework to control your Pi from the web
http://store.raspberrypi.com/projects/webiopi
http://code.google.com/p/webiopi/
http://trouch.com
by thivtulz » Fri Dec 28, 2012 3:05 am
I want to create a FORM and put button and also update Labels using python.So how to do that.I'm new for python.
by KenT » Fri Dec 28, 2012 10:04 am
Use Tkinter
Tutorial here http://effbot.org/tkinterbook/tkinter-index.htm
There are other more complicated and newer gui toolkits but Tkinter is the ready installed native Python toolkit.
Pi Presents - A toolkit to produce multi-media interactive displays for museums, visitor centres, and more
Download from http://pipresents.wordpress.com
by Kaspaas » Mon Dec 31, 2012 6:12 pm
I had the same problem as the initial question: How do I run a Python script.
Wrote a quick blog on this - I now know 3 ways to do this.
See
First Python steps on my Raspberry Pi http://nvdd.info/Vs7JFk
by thivtulz » Fri Jan 04, 2013 12:44 am
Hi.Can i know what are the errors in my coding..
imprt pygtk
import gtk
class Helloworld:
def _init_(self):
self.window = gtk.wwindow()
self.window.set_title(("GTk Hello World = By Promosys")
self.window set_default_size
self.window.connect("destroy", self.quit)
self.verticalcontainer.margin=5
self.window.add(self.verticalcontainer)
self.verticalcontainer.show()
self.menuBar= gtk.MenuBar()
self.fileMenuItem=gtk.MenuItem("File")
self.fileMenu = gtk.Menu()
self.lightmyLEDMenuItem = gtk.MenuItem("Light My LED !!!")
self.lightmyLEDMenuItem.connect("activate", self.lightmyLEDMenuItem_clicked)
self.fileMenu.add(self.exitMenuItem)
self.exitMenuItem.show()
self.fileMenuItem.set_submenu(self.fileMenu)
self.fileMenu.show()
self.menuBar.add(self.fileMenuItem)
self.fileMenuItem.show()
self.verticalcontainer.add(self.menuBar)
self.menuBar.show()
self.btnHelloworld =gtk.Button("hello World")
self.btnHelloworld.connect("clicked", self.btnhelloworld_clicked)
self.verticalcontainer.add(self.btnHelloworld)
self.btnHelloworld.show()
self.imageBox.set_from_file("pi.png")
self.verticalcontainer.add(self.imageBox)
self.imageBox.show()
self.window.show()
def btnHelloworld_Clicked(self, widget, data = Name):
self.messageBox = gtk.MessageDialog(flags = gtk.DIALOG_MODAL, buttons = gtk.BUTTONS_OK,message_format = "Hello World")
self.messageBox.format_secondary_text("By Promoys")
self.messageBox.connect("response", self.messageBox_Response)
self.messageBox.show()
def messageBox_Response(self, widget, data = Name):
if data == gtk.RESPONSE_OK:
self.messageBox.hide()
def quit(self, widget, data = Name):
gtk.main_quit()
def exitMenuItem_Clicked(self,widget, data = Name):
gtk.main_quit()
def main(self):
gtk.main()
if _name_ == "-main_":
helloworld = Helloworld()
helloworld.main()
by alexeames » Fri Jan 04, 2013 9:40 am
You need to post you code between code tags.
If you look at the buttons above the text box when writing a post, you have...
B i u Quote Code
Click the Code one, then paste your code, then click it again. Then it will be readable...
like this
Alex Eames RasPi.TV HDMIPi.com RasP.iO
by Rubber131186 » Fri Jan 04, 2013 9:41 pm
This helped alot putting :-
#! /usr/bin/python
at the top of my .py or pyw files and right clicking on them and going to properties, permissions, make this file executable.
Is there a way to now make a icon for the file.py ? And to have it so you double click and the file.py just run's instead of [execute] [execute in terminal] [open] or [cancel] ?
What if my python program had like music.mid file's and image.png file's how do i package this into like a file.exe so i just double click and the game app just run's with everything it needs to hand. I am really new to python and to linux. Only ever used yellow dog linux on the playstation 3 till it was removed with a update.
