System Clock?
General programming chat and advice for beginners
by Scotty T » Fri Jun 01, 2012 1:31 pm
So there is no battery on board. How does Pi keep the time?
I'm assuming it doesn't.
Is there a built in ntp for debain squeeze or does one need to be install. If so, which is the best one to use?
by SN » Fri Jun 01, 2012 1:36 pm
thats right - on the debian image at least it will remind you to set the time if you have no internet connection, but it does make a best guess of the time (based on the last time it had before it was shutdown last time)
Steve N – binatone mk4->intellivision->zx81->spectrum->cbm64->cpc6128->520stfm->pc->raspi ?
by bredman » Fri Jun 01, 2012 1:36 pm
NTP is enabled by default in Debian.
No need to worry.
by Scotty T » Fri Jun 01, 2012 1:39 pm
where is the ntp configuration? I'd like to review it.
by bredman » Fri Jun 01, 2012 1:46 pm
/etc/ntp.conf
In case you are wondering, I found it in 5 seconds with the command
sudo find /etc | grep ntp
by piguy79 » Tue Jun 05, 2012 5:00 am
does the raspberry pi keep time with software? i'm trying to understand if i can use timed events in my programming. i have an original xbox and when i plug it in it asks me for the time and date and then after i type it in it keeps time somehow until i unplug it again is the raspberry pi like that or is it totaly without any concept of time?
by godFather89 » Tue Jun 05, 2012 5:15 am
No operating system can work without the sense of time. Most likely, it uses a timer embedded in the ARM.
by jecxjo » Tue Jun 05, 2012 1:38 pm
If you look in the BCM2835 documentation Chapter 12 covers the System Timer internal to the CPU. This is the peripheral you'd use to calculate time changes on your system. There is a 64-bit free running counter and if you were to catch the interrupt when this is triggered, do a little math based on your clock frequency and now you have a clock. Since there is no battery backed Real Time Clock on this board you'd have to reset your current "Time" using NTP as stated in previous posts.
IRC (w/ SSL Support): jecxjo.mdns.org
Blog: http://jecxjo.motd.org/code
ProjectEuler Friend: 79556084281370_44d12dd95e92b1d9453aba2bdc94101b
by jeradsaxton » Sat Aug 04, 2012 2:27 am
ok maybe im an idiot, but i have tried to change the system clock with no avail. i have wheezy installed and functioning but i cannot change the time. PLEASE HELP getting very frustrated
by jbranko » Sun Aug 12, 2012 1:09 pm
Hi.
System clock on my rpy is for example 15:00. Because I'm in another timezone I want to set system clock to 16:00. Can I do this permanently? I set correct time, but when I restart rpy, time goes back for 1 hour.Thank you for help.
by BlackJack » Sun Aug 12, 2012 3:21 pm
@jbranko: You should not change the clock but tell the system your time zone. If you are using the wheezy debian image from the raspberrypi.org download section start sudo raspi-config and set the correct time zone.
while not self.asleep():
    sheep += 1
by DavidDunn » Sun Aug 12, 2012 3:33 pm
Got it! Now I'm on French time.
Many thanks
David
