Emulator for Mac
General programming chat and advice for beginners
by yash.ranadive » Tue Jul 10, 2012 6:36 am
Sorry for asking a n00b question but what is the best way to set up an emulator for Debian/other OS to emulate hardware of Raspberry Pi on a Mac. I'm running Snow Leopard. I tried to follow the instructions at http://igor.gold.ac.uk/~mas01mjy/wp/?p=95 but the QEMU hangs on me.
Any help would be appreciated
by gazmandev » Wed Jul 11, 2012 10:16 am
I've got the same problem. I start qemu-system-arm and all I get is a white screen, the magic beachball and that's it until I go all Darth Vader and force kill the whole thing. I've tried various different images, QEMU options. I even got one up and running under windows, copied it back and same result - white screen, beachball, Sith Lord. I have tried downloading and running Q to try and get it going. All to no avail.
Any suggestions would be greatly appreciated.
Gareth
by gazmandev » Wed Jul 11, 2012 10:23 am
In addition to my previous reply, I am running an up to date MBP/OSX10.7.4 with QEMU installed from Macports as described in the OP weblink.
by kentaroyamada » Thu Jul 12, 2012 11:05 am
I too have exactly same problem.. sorry I am not helping..
by kryounger » Fri Jul 13, 2012 10:10 pm
use virtualbox
it's free and can boot most of the Pi images
by yash.ranadive » Sat Jul 14, 2012 1:26 am
kryounger, will virtual box mimic the hardware on the Pi? I run a fast mac and want to make sure the dev I do on the virtual box will be replicated speed-wise on the Raspberry Pi.
by Towabohu » Wed Mar 19, 2014 7:56 am
Moin, moin folks,
I have success with "QEMU emulator version 1.7.0, Copyright (c) 2003-2008 Fabrice Bellard" installed on Mac OS X 10.9.2 (Maverick) through http://www.macports.org/ (Version: 2.2.1).
I have tried the distribution which was coming with c't- Journal 7/2014 (http://www.heise.de/ct/heft/2014-7-Emul ... 35387.html). Unfortunately I don't know what "kernel-qemu" they used, but after unpacking the zip-Archive, changing in the directory the command line:
qemu-system-arm -kernel kernel-qemu -cpu arm1176 -m 256 -M versatilepb -append "root=/dev/sda2 panic=1" -hda 2013-12-20-wheezy-raspbian.img -redir tcp:2222::22
starts a RaspberryPi with redirected ssh port.
Good luck
