Question about autostart program in LXDE
General programming chat and advice for beginners
by hzhwang » Fri Jan 04, 2013 12:17 am
Hi everybody,
I wrote a python script using Tkinter and GPIO, so far it works fine.
I hope to start it in a more simple way: Just connect power, RaspberryPi will boot, start LXDE and run my python script automatically.
But I have no idea how to start python script with sudo(or run as root , because it uses GPIO)
I tried add them ~/.config/autostart/auto.desktop or .xsession but not working, maybe I mistake something..
Any ideas or suggestions would be greatly appreciated
My RaspberryPi playground http://ezzep.blogspot.com
by -rst- » Fri Jan 04, 2013 12:43 pm
Shouldn't that be ~/.config/autostart/.desktop (not auto.desktop)? http://wiki.lxde.org/en/Autostart
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
by hzhwang » Fri Jan 04, 2013 2:28 pm
-rst- wrote:Shouldn't that be ~/.config/autostart/.desktop (not auto.desktop)? http://wiki.lxde.org/en/Autostart
Thanks for reply, much appreciated
I had tried setting them in ~/.config/autostart/.desktop before, but still not working.
Maybe I am setting wrong command, here is my .desktop (autostart.desktop) file:
[Desktop Entry]
Name=Timer
Comment=Start Timer script
Exec="gksu python /home/pi/timer.py" (I tried '/usr/bin/sudo /usr/bin/python /home/py/timer.py' too, still the same)
by Ph1lj2 » Fri Jan 04, 2013 3:43 pm
hzhwang wrote:Hi everybody,
Hi
Did you ever get this to work - like you I'm trying to fire-up a python script that uses Tkinter and GPIO
so far not getting anywhere
I've tried Crontab - seems to have no effect
Any help would be appreciated
by hzhwang » Fri Jan 04, 2013 10:36 pm
Hi
Finally I found the answer, use LXSession
http://wiki.lxde.org/en/LXSession#Automatically_start_some_applications_on_login
First, add
#!/usr/bin/env python
in the first line of python script, and make the file executable with it, like
chmod +x timer.py
Second, edit(or create) LXSession file in path
~/.config/lxsession/LXDE/autostart
and add this line:
/usr/bin/sudo ~/timer.py
if python script not start successfully, you can check the ~/.xsession-errors file
Below video link shows how it works
http://www.youtube.com/watch?v=7yTRxifqIdQ
by Ph1lj2 » Mon Jan 07, 2013 5:28 pm
Hi
First, add
chmod +x timer.py
and add this line:
Hi
thanks for the suggestions, I tried it today :-
firstly I could not find the appropiate folder "~/.config/lxsession/LXDE/autostart", so after reviewing the link I put my autostart file in the /usr/share/lxsession and created a new folder LXDE
- no joy
The contents of my autostart file was
" sudo /home/pi/mcp3008/ python b1g.py"
Unfortunately this achieved nothing
Any ideas ?
by hzhwang » Mon Jan 07, 2013 10:39 pm
Ph1lj2 wrote:
Hi
- no joy
Any ideas ?
My environment is Raspbian “wheezy” (2012-12-16), not sure it will be some different or not
Here is my runtrought
0.write a simple python script(like 'boottest.py'). when execute it,it will generate a file 'working'. (Remember setting it executable and add #!/usr/bin/env python in file)
1.find ~/.config/lxsession/LXDE/autostart
cd /home/pi
cd .config
cd lxsession
cd LXDE
2.
vi autostart
and add this line:
/usr/bin/sudo ~/boottest.py
Reboot system.
If lxsession setting is correct, a file 'working' would appear in your home directory, if not appear, check the ~/.xsession-errors log file
3.replace boottest.py with what python script you want execute (like b1g.py) and check it working correctly or not.(In this step you have better test it with RaspberryPi connects monitor directly.)
by -rst- » Tue Jan 08, 2013 12:18 pm
hzhwang wrote:1.find ~/.config/lxsession/LXDE/autostart
cd /home/pi
cd .config
cd lxsession
cd LXDE
To make that more generic (= to work for other users than 'pi' as well):
# instead of cd /home/pi
cd  ~
(~ is a 'shortcut' to the current user's home dir - usually '/home/<username>')
In addition, if some of those directories is missing, just create then before cd'ing into... f.eg. 'mkdir .config'
by Nexus12 » Fri Jan 11, 2013 1:46 am
cd /home/pi
cd .config
cd lxsession
cd LXDE
cd  ~
Cool managed to get it to work - thanks for your help
Will continue testing soon
Cheers
