Crypto Currency (Bitcoin/Litecoin) on a Pi
by bitguy » Sat May 18, 2013 7:50 pm
How to install the bitcoin daemon on a Raspberry Pi (also works for litecoin, feathercoin, etc...)
IMPORTANT NOTES:
a line starting -- is a comment, just read it.
a line starting > is a command, just type it and press "Enter".
This will work on a Raspberry Pi Model B with 256 Mb of RAM.
The current bitcoin blockchain is about 9Gb.
Make sure that you have enough room on either your sd-card or an attached device to hold this file.
Remember it is only going to get bigger!
This also works for any of the bitcoin based crypto-currencies, simply change the git url and navigate to the relevant directory.
!!!!SECURITY!!!!
If you are running this as a daemon, permanently connected to the internet make sure that you install and configure iptables and fail2ban at the very least. It is also wise to setup SSL for RPC connections.
OBTAINING AND COMPILING THE BITCOIN CLIENT
-- Update all existing software on the Pi
> sudo apt-get update
> sudo apt-get upgrade
-- Install the prerequisites required for compilation
> sudo apt-get install checkinstall subversion git git-core build-essential
> sudo apt-get install libssl-dev libdb++-dev libminiupnpc-dev
> sudo apt-get install libboost-dev libboost-system-dev libboost-filesystem-dev libboost-program-options-dev libboost-thread-dev
-- Go to your home directory
> cd ~
-- Obtain a copy of the latest version of the bitcoin client
> git clone git://github.com/bitcoin/bitcoin.git
-- We need a large swap file for this to work, the temp files can easily get to 500Gb.
> sudo nano /etc/dphys-swapfile
-- Modify the line to change the setting from 100Mb to 500Mb.
-- change CONF_SWAPSIZE=100 to CONF_SWAPSIZE=500
-- Exit from nano
> ctrl-o
> enter
> ctrl-x
-- Reset the swapfile to implement the new size or just reboot, probably safest to just reboot.
> sudo dphys-swapfile setup
> sudo dphys-swapfile swapoff
> sudo dphys-swapfile swapon
-- To check all is OK run the free command.
> free
-- Check that the swap total is ~500000
-- Navigate to your downloaded bitcoin source files
> cd ~/bitcoin/src
-- Compile it! This will take a looooooonnnnnggg time. Mainly because your swap is on the sdcard and it is slooooowwwwww.
-- Seriously, I sanded and washed down the skirting and doors in a bedroom, then had lunch, then painted it in the time it took to compile.
> sudo make -f makefile.unix
-- Make it smaller by removing unneeded assemblies and what not.
> strip --strip-unneeded bitcoind
-- Run it!
> ./bitcoind -daemon
CONFIGURING THE DAEMON
-- Use the information located at https://en.bitcoin.it/wiki/Running_bitcoind and follow the instructions!
-- Whilst compiling you can open a separate shell and use the "free" command to monitor the memory usage.
-- You can use the compilation for temperature benchmarking by entering the following command in a new shell.
> /opt/vc/bin/vcgencmd measure_temp
BTC: 18HQQv1rmEkByDWNi8UMWf2FLd9DvQ3ryg
by bitguy » Sun May 19, 2013 11:35 am
UPDATE FOR LITECOIN:
You may receive this error message:
"An error occured while setting up the RPC port 9332 for listening: open: Address family not supported by protocol."
This is because litecoin needs IPv6 enabled.
To test this is the problem you can manually load the ipv6 module by typing
> sudo modprobe ipv6
and then restarting litecoin.
To permanently fix this error you need to modify the boot-time modules:
> sudo nano /etc/modules
Add the line "ipv6" without the quotes to the end of the file and restart the Pi.
I have also been asked how to view what the client is doing. To monitor the client directly rather than by RPC use the command:
> ./litecoind -printtoconsole
by fulltimedreamer » Mon May 20, 2013 7:23 am
Could you show us the hashrate for both BTC and LTC?
by bitguy » Tue May 21, 2013 3:19 pm
I haven't got Bitcoin installed on a Pi anymore because I took it off to play with Litecoin.
I have just tested Litecoin and I get a grand total of ~56 hashes per second or 0.056Kh/s.
I was thinking more of using the Pi as a secure, portable wallet.
by marked » Fri May 24, 2013 3:49 pm
for litecoin, cpuminer-2.2.3 gets approx 0.39khash/s with overclock of the cpu at 900Mhz
though today it appears to be running slightly higher...
[2013-05-24 16:41:49] thread 0: 15231 hashes, 0.45 khash/s
[2013-05-24 16:42:11] LONGPOLL detected new block
[2013-05-24 16:42:11] thread 0: 9990 hashes, 0.45 khash/s
[2013-05-24 16:43:11] thread 0: 27244 hashes, 0.45 khash/s
[2013-05-24 16:43:13] thread 0: 945 hashes, 0.45 khash/s
[2013-05-24 16:43:13] accepted: 3972/4051 (98.05%), 0.45 khash/s (yay!!!)
[2013-05-24 16:44:12] thread 0: 26388 hashes, 0.45 khash/s
http://sourceforge.net/projects/cpuminer/files/pooler-cpuminer-2.2.3.tar.gz
currently that is generating at a rate of about 0.0009 ltc a day.
marked
by merlz42 » Wed May 29, 2013 11:25 am
The pi does just over 300 khash/s for bitcoin on CPU (from memory). I have some ideas and shader code for doing it on GPU, but no time at the moment to write up a client and see how fast it is.
by scruss » Wed May 29, 2013 11:34 am
You might get very slightly faster results if you enable the SoC's hardware random number generator. It might not make a noticeable difference.
