GCC
by Patrick222122 » Fri Dec 28, 2012 2:39 pm
I heard that GCC is the best C compiler for the pi, but I am having trouble firguring out how to download it. I know you have to do through a mirror site but when I checked a few of the american sites. All I found was list of foulders. Do I have to download every one, one by one or is there something I am missing?
by Cloudcentric » Fri Dec 28, 2012 3:00 pm
What Linux Distribution are you running ?
I know everything about nothing"
by joan » Fri Dec 28, 2012 3:04 pm
I'd expect it is already installed.
Try gcc from the command line.
by johnbeetem » Fri Dec 28, 2012 3:07 pm
GCC should be present in standard GNU/Linux distributions. Open a terminal window and enter "gcc -v" and if GCC is present it will tell you which version is installed.
by efflandt » Sat Dec 29, 2012 7:45 am
It is in the repositories. If you do not have it in Raspian:
sudo apt-get update && sudo apt-get -y dist-upgrade
sudo apt-get gcc
I am not familiar with Arch.
by AndyD » Sat Dec 29, 2012 8:14 am
This may work better
sudo apt-get install gcc
... sorry @efflandt
by Cloudcentric » Sat Dec 29, 2012 9:21 am
AndyD wrote:This may work better
... sorry @efflandt
Will only work with Linux Debian based Distro's..................
The OP may be using Fedora or Arch or Slackware or RiscOS or TinyCore etal
by AndyD » Sat Dec 29, 2012 9:48 am
Cloudcentric wrote:Will only work with Linux Debian based Distro's..................
Yes indeed!
