fldigi working - HAM Radio
by flask28 » Mon Oct 29, 2012 9:27 am
After a bunch of messing around I finally got the ham radio digital mode application fldigi working on my Pi. I'm running the rev b board and the latest greatest firmware/wheezy updates.
For a soundcard I used a USB Signalink I had sitting here. The nice part about a signalink is it handles PTT for me and presents as a usb soundcard to the Pi. But I'm sure you could use a cheap usb soundcard and a ptt-type cable (or vox even) to do the same thing and much of this should apply.
I've never played with linux sound before, so I apologize if I sound stupid. Don't need sound on servers! So this is my first time mucking about with ALSA.
When I plugged in the signalink I saw it was discovered and watched some drivers get loaded on the console. I was pretty excited about that right there.
The command "aplay -l" showed me:
**** List of PLAYBACK Hardware Devices ****
card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 1: CODEC [USB Audio CODEC], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Card 0 is the internal soundcard, and Card 1 is my signalink. A good sign! This is telling me the signalink has registered with ALSA as an output device. Cool, let's check for an input device.
The output of 'arecord -l" showed:
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
And "cat /proc/asound/cards" output:
  0 [ALSA           ]: BRCM bcm2835 ALSbcm2835 ALSA - bcm2835 ALSA
                      bcm2835 ALSA
 1 [CODEC          ]: USB-Audio - USB Audio CODEC
                      Burr-Brown from TI USB Audio CODEC at usb-bcm2708_usb-1.3, full speed
So far so good. The internal soundcard does not have a capture device, so just card 1 is showing up. The program 'alsamixer' is showing both cards, and I can select between them. I don't see a capture device in alsamixer though, and that's freaking me out. Turns out I got it working and never had the capture device show in alsamixer so that was no biggie.
The fldigi package didn't fire up for me, I'm not sure why, so I ended up compiling it from source. I had to add a bunch of packages as you'd expect but finally it compiled and worked. If the package loads for you I'm jealous. But once I got it loaded, I saw I couldn't select any devices in the soundcard config.
After reading the fldigi linux recommendations I figured using the portaudio library on top of ALSA was the way to go. So I installed the portaudio packages and recompiled fldigi with portaudio support (your working package probably has this already). I fired up fldigi and could suddenly select port audio devices - and my signalink was in there as the USB Audio CODEC as a playback and capture device. YES!!
But it didn't work. I wasn't getting any signal in fldigi, no waterfall. The capture wasn't working.
I tried a million things, but I think I know what fixed it. I added the singalink explicitly as a device listed in /etc/asound.conf. Here's what my asound.conf file looks like:
pcm.mmap0 {
type mmap_emul;
slave {
pcm "hw:0,0";
pcm.slink {
type hw;
slave {
pcm "hw:1,0";
pcm.!default {
type plug;
slave {
pcm mmap0;
As soon as I did that I had a working waterfall in fldigi. I did a quick tx test and PTT got triggered. I need to make a contact with someone local here to be sure (I am using a vhf radio for this atm) but it's looking pretty good so far.
Since a soundcard is a soundcard, I bet this will work for the cheapie usb soundcards too. I have a few of those I'm going to try next - not that I have a cable to connect it to my radio yet. Well, next is AX25 and soundmodem. I have my KPC3+ connected via the GPIO and console access works fine, but I have not set it up as a native KISS AX25 device for ARPX or the like. I'd like to see if I can go without a TNC. That would be nice.
by andytuk » Tue Oct 30, 2012 2:39 pm
This is on my list of things to try on my Pi - thanks for the info.
I will be using my homebrew interface to my Yaesu FT-847.
Andy(2E0GPU)
by boyo » Thu Nov 01, 2012 4:20 am
This post is what I have been looking for, and has single handedly moved the raspberry pi to the top of my Christmas list.
by flask28 » Fri Nov 02, 2012 9:38 pm
One other configuration tip.
I had problems triggering the transmit through FLDIGI until I added an an environment variable. Be sure to set:
PA_ALSA_PLUGHW=1
by g1rnz » Thu Nov 15, 2012 1:49 pm
Hi I got fldigi to install without issue on my rev b R-pi and am using a signalink usb interface. The problem is that it seems to use full cpu and will not anything. Has anyone success in decoding psk-31.
by flask28 » Thu Nov 22, 2012 8:21 pm
Yep, I had the same problem decoding, fldigi is super cpu-intensive.
I finally got it decoding psk31 with a hefty overclock (default turbo settings) but that overclock corrupts the SD card pretty quickly, I never got more than a few psk contacts before I saw the SD write errors start popping up.
So now I'm trying to find an OC that the RPi can cope with and hopefully that'll be enough for fldigi.
FYI, soundmodem worked much better with the OC as well. My packet decode rates seemed to improve dramatically. I think the RPi might be just a little underpowered for these massive floating point-based services.
by cartman » Mon Jan 21, 2013 8:36 pm
flask28: Were you able to get soundmodem decoding AX25 packets? I've tried with a few USB soundcards and a Signalink and the waveform is there but no decoding. It works the first time on my desktop with fc17 and netbook using Ubuntu 12.10.
73,
Gary
VE6UQ
by F5VLB » Sun Apr 06, 2014 2:53 pm
Hello, I am interested by this solution to equip my volunteers in the scope of our participation to emergency networks in cas of accidents,troubles, ...
Is it possible to have an email to contact you enabling me to establish a procedure how to install and use FLDIGI on a raspberry ? This will be great !
regards
f5vlb@kermaz.com
John
F5VLB
by hampi » Mon Apr 07, 2014 9:39 pm
F5VLB wrote:Is it possible to have an email to contact you enabling me to establish a procedure how to install and use FLDIGI on a raspberry ?
I tried apt-get install fldigi, but that seems to be broken in my rasbian version.
by robrob » Fri Jan 16, 2015 5:01 pm
I am using my raspberry pi as an APRS internet gate and digipeater (simultaneously) using only DireWolf (sound card modem software) and a tigertronics Signalink USB (sound card) connected to a 2 meter Kenwood TM-241a. The cpu usage is very low with this setup. The installation detail is here: http://home.comcast.net/~wb2osz/Version%200.6/Raspberry-Pi-APRS.pdf
Rob
K9OJ
by robrob » Fri Jan 16, 2015 5:15 pm
I do have fldigi working on my pi. It's running in standard 'Turbo' mode and I've done all the wheezy updates. I installed fldigi with the apt-get install command. The Signalink USB was found and I selected it for rx and tx in the 'Port Audio' config section. The waterfall works fine and I can transmit too. The cpu graph is running pretty high though but fldigi is working.
Rob
K9OJ
by robrob » Mon Mar 09, 2015 6:19 pm
The new raspberry pi 2B with quad core cpu and 1G memory is now out for the standard price of $35. I replaced my old pi with a 2B and fldigi runs at about 20% cpu usage (using pi 2B overclock setting).
by OregonJim » Fri Mar 13, 2015 2:01 am
Hello.
I am successfully using then Raspberry Pi model 2 with both fldigi and qsstv but I still need to get PTT working. I installed bw_tools and the git programs but I cannot use gpio_???? as the system tells me it is not installed. As such I cannot assign RTS nor CTS to one of the GPIO pins.
Not that I am NOT using a signal link, but am using the cmedia audio USB adaptor and directly coupling the audio in/out to the radio (5-watt X1M) which likes the levels very well. This particular radio has no line in/out, not any sort of data interface, so I must assert PTT by shorting the SLEEVE and RING on the microphone input jack. At the moment, I have a couple of bare wires that I short to start PTT, which I want to connect to a @N3904 (or 6 as appropriate) that I would like to trigger with RTS.
Anyone have some idea how to set this up? The reason I am wanting to use RTS is so that ANY Ham software can operate PTT by using the "serial port" RTS line. This keeps it simple and repeatable.
A VOX circuit is also on order.
Any ideas guys?
73 Jim KI7AY
by OregonJim » Thu Mar 26, 2015 3:09 am
Has anyone managed to get RTS assigned to one of the GPIO pins for PTT? I cannot seem to do that, and the VOX circuit I bought isn't compatible. It activates the relay and puts the radio in transmit as soon as I power it up.
So, I want to use the onboard GPIO pin that can be assigned as RTS, but I need a little help doing that. I'll drive a 2N3904 (or more likely a 2N3906 since it looks like RTS is normally High), which will in turn operate a small relay for PTT.
All help is appreciated.
73 Jim KI7AY
