Install wireless driver in BerryTerminal (Edimax EW-7811Un)
by gene » Sun Nov 04, 2012 8:27 am
I am attempting to use my Raspberry Pi as a LTSP thin terminal via BerryTerminal, however the driver for my wireless adapter isn't included in that distribution.
Can anyone point me to instructions in order to do this?
Raspberry Pi: Model B, 256 MB RAM
Wireless adapter: Edimax EW-7811Un
OS: BerryTerminal (via BerryBoot)
by hunternet93 » Fri Nov 09, 2012 8:19 pm
Based on a Google search, the card uses a Realtek chipset. You should be able to get it working with the command:
sudo apt-get install -y firmware-realtek
You'll need to enter your password when it asks. After the command completes, you should be able to connect.
by geharvey » Mon Mar 31, 2014 2:44 pm
I have read your post and was wondering; did you ever get the Berryterminal to boot from the LTSP server wirelessly with your Edimax wireless adaptor? I have been trying for days to get this to work. I have the wireless driver source code and have compiled it with the cross compiler within the Berryterminal code, against the kernel source tree in the Berryteminal code and have produced a loadable module for the Edimax wireless adaptor, but the module is reported to have an incompatible format by the kernel, when I try to insert it. This is a common problem, I believe.
Many thanks,
Graham.
