8000 interrupts per second when idle!
140 posts   Page 4 of 6   1, 2, 3, 4, 5, 6
by dom » Thu Aug 23, 2012 9:40 am
We have the FIQ patch working on the 2.91 USB driver. Something in the update to 2.94 broke it.
We've got someone investigating.
by samsamsam » Mon Aug 27, 2012 9:48 am
dom wrote:We have the FIQ patch working on the 2.91 USB driver. Something in the update to 2.94 broke it.
Is there any progress with this patch?
by jamesh » Mon Aug 27, 2012 7:07 pm
Bank holiday weekend in the UK - so probably not much work done the last three days. Patience is required!
Volunteer at the Raspberry Pi Foundation, helper at Picademy September, October, November 2014.
by samsamsam » Mon Aug 27, 2012 7:29 pm
Oki :) I am patient. Oki :) I am patient. I just asked...
by samsamsam » Fri Aug 31, 2012 8:48 pm
Does someone still working on this patch to port it to the new driver?
by dom » Fri Aug 31, 2012 10:10 pm
samsamsam wrote:Hello,
Good news. Costas (one of our interns) found the problem earlier today. I'm just testing, and if it looks good will push it out tomorrow.
Looks to give about 10% performance boost to the Pi, without the side effects of the SOF patch.
by dom » Sat Sep 01, 2012 12:06 am
FIQ patch is pushed. Get it from rpi-update. It is disabled by default, but add:
dwc_otg.fiq_fix_enable=1
to cmdline.txt to test. It should give about 10% extra performance to ARM when USB is not busy. It shouldn't change behaviour of USB.
by samsamsam » Sat Sep 01, 2012 8:04 am
Super news :) I am going to test this patch :)
Thank you very much! :)
by dom » Sat Sep 01, 2012 10:43 am
You can check the number of interrupts per second with and without this patch with:
sh -c "cat /proc/interrupts | grep dwc && sleep 10 && cat /proc/interrupts | grep dwc" | awk '{ if (s==0) s=$2 } END { print ($2-s)/10 }'
You should get 8000+ when the patch is disabled.
You should get 600+ when the patch is enabled. This will vary based on USB devices connected and how busy they are. When USB is running flat out you may see 8000+.
by samsamsam » Sat Sep 01, 2012 11:23 am
Thanks for info.
I will test this patch tonight, however without patch I get:
root@raspberry-pi:/etc/oscam# sh -c "cat /proc/interrupts | grep dwc && sleep 10 && cat /proc/interrupts | grep dwc" | awk '{ if (s==0) s=$2 } END { print ($2-s)/10 }'
3564
Is it possible? I use network and 4 ftdiToRs232 converters and 1GB pendrive with root partition.
vmstat give me similar results
root@raspberry-pi:/etc/oscam# vmstat
procs -----------memory---------- ---swap-- -----io---- -system-- ----cpu----
 r  b   swpd   free   buff  cache   si   so    bi    bo   in   cs us sy id wa
 0  0      0 205592   3880  17240    0    0     0     0 3742  161  1  1 95  2
by dom » Sat Sep 01, 2012 12:00 pm
samsamsam wrote:Is it possible? I use network and 4 ftdiToRs232 converters and 1GB pendrive with root partition.
I don't think so. You haven't enabled SOF reduction have you?
Is it any different with the USB devices unplugged?
by samsamsam » Sat Sep 01, 2012 12:25 pm
My command line:
Kernel command line: dma.dmachans=0x3c bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0x2 bcm2708.serial=0xec6c4cc5 smsc95xx.macaddr=B8:27:EB:6C:4C:C5 dwc_otg.microframe_schedule=1 smsc95xx.turbo_mode=N sdhci-bcm2708.missing_status=0 sdhci-bcm2708.sync_after_dma=0 dwc_otg.lpm_enable=0 console=tty1 root=/dev/sda1 rootfstype=ext4 rootwait dwc_otg.speed=1
Maybe it is related to parameter dwc_otg.speed=1 or smsc95xx.turbo_mode=N? I can not test what happens when I unplug device now but tonight I will test this also.
I must use dwc_otg.speed=1 because without this my FTDI devices always restart. It is probably similar problem to the: http://www.mail-archive.com/linux-usb-u ... 14694.html
by dom » Sat Sep 01, 2012 12:39 pm
samsamsam wrote:My command line:
Yes, dwc_otg.speed=1 limits speed to full speed (rather than USB 2's high speed) protocol, and so only 1000 interrupts/sec when idle.
This patch will have much less benefit if you are using dwc_otg.speed=1.
by samsamsam » Sat Sep 01, 2012 12:45 pm
Yes I know :) However I think that the patch will make my RPI more stable. Although right now my RPI is very stable after night battles :)
OFFTOP
What do you think can I restore the root partition on SD card since the patch: "low-latency mode to sdcard driver"?
If yes what value should be set for the parameter sdhci-bcm2708.missing_status?
by dom » Sat Sep 01, 2012 1:00 pm
samsamsam wrote:What do you think can I restore the root partition on SD card since the patch: "low-latency mode to sdcard driver"?
sdhci-bcm2708.missing_status is not recommended now, just leave it off command line. The sdhci-bcm2708.enable_llm is now enabled by default and fixes the USB latency problem caused by sdcard a safer way.
by samsamsam » Sat Sep 01, 2012 1:14 pm
Thank you very much for your help:) I will move my root partition to the SD and test these two patches:)
Thanks once again :)
by samsamsam » Sun Sep 02, 2012 7:37 am
Stats with new kernel and root partition moved to SD card:
root@raspberry-pi:~# vmstat
 0  0      0 179380  27148  17624    0    0     0     0 3316  141  2  2 93  4
Kernel command line: dma.dmachans=0x3c bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0x2 bcm2708.serial=0xec6c4cc5 smsc95xx.macaddr=B8:27:EB:6C:4C:C5 dwc_otg.microframe_schedule=1 smsc95xx.turbo_mode=N dwc_otg.fiq_fix_enable=1 sdhci-bcm2708.sync_after_dma=0 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait dwc_otg.speed=1
So far, the system is stable :)
by Koenkk » Sun Sep 02, 2012 12:18 pm
Not working for me, getting a kp at boot (details: http://i.imgur.com/PfJG0.jpg). I ran rpi-update. cmdline.txt is containing : dwc_otg.fiq_fix_enable=1. Kernel: 3.2.27+ #102 PREEMPT Sat Sep 1 01:00:50 BST 2012 armv6l.
by dom » Sun Sep 02, 2012 12:28 pm
Koenkk wrote:Not working for me, getting a kp at boot (details: http://i.imgur.com/PfJG0.jpg). I ran rpi-update. cmdline.txt is containing : dwc_otg.fiq_fix_enable=1. Kernel: 3.2.27+ #102 PREEMPT Sat Sep 1 01:00:50 BST 2012 armv6l.
Looks like it can't find rootfs. Is your rootfs on sdcard, or are you using nfs/usb?
Does dwc_otg.fiq_fix_enable=0 allow it to boot? Does reverting kernel allow it to boot?
by samsamsam » Sun Sep 02, 2012 12:31 pm
cmdline.txt should contain at least:
by Koenkk » Sun Sep 02, 2012 12:33 pm
samsamsam wrote:cmdline.txt should contain at least:
working, thanks for this uber fast response!!
by rtramon » Sun Sep 02, 2012 12:46 pm
Updated firmware with rip-update set the cmdline option, and after some time my headless system becomes inaccessible with the following error in /var/log/messages:
Sep 2 14:37:34 raspi kernel: [ 8406.167322] smsc95xx 1-1.1:1.0: eth0: Failed to w
rite HW_CFG_LRST_ bit in HW_CFG register, ret = -110
Sep 2 14:37:40 raspi kernel: [ 8412.167492] smsc95xx 1-1.1:1.0: eth0: Failed to w
rite register index 0x00000014
(repeated many times)
cmdline.txt:
dwc_otg.lpm_enable=0 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait sdhci-bcm2708.sync_after_dma=0 dwc_otg.microframe_schedule=1 dwc_otg.fiq_fix_enable=1
Also interupts per seconds is 44K! like normally on my system using pl2303 usb to rs232 converter reading serial output from small measurement system.
by samsamsam » Sun Sep 02, 2012 1:02 pm
You can try to add line
vm.min_free_kbytes = 16384
at the and of file /etc/sysctl.conf
And add parameter smsc95xx.turbo_mode=N to the cmdline.txt
by dom » Sun Sep 02, 2012 1:03 pm
rtramon wrote:Sep 2 14:37:34 raspi kernel: [ 8406.167322] smsc95xx 1-1.1:1.0: eth0: Failed to w
cmdline.txt:
If you change to dwc_otg.fiq_fix_enable=0 does the problem go away?
If you change to dwc_otg.microframe_schedule=0 does the problem go away?
by bitwelder » Sun Sep 02, 2012 8:32 pm
I applied the patch and in my case (nothing attached to USB) interrupts went from 8000+ to 290.
Question: is there any known 'side effect' to this FIQ patch, or any conditions where it may not be convenient to activate it?
