adc pi v2.2
by zenobi » Sun Oct 27, 2013 8:47 pm
hi
i cant start with the adc pi
from www.abelectronics.co.uk/products/3/Raspberry-Pi/17/‎Vertaal deze pagina
Raspberry Pi Analogue to Digital converter, 8 Channel ADC
i have always error :
  File "./adc_demo.py", line 11, in <module>
    import quick2wire.i2c as i2c
ImportError: No module named quick2wire.i2c
i dont understand step : " enable Python to access the API by adding export PYTHONPATH=$PYTHONPATH:$HOME/quick2wire-python-api to the end of ~/.profile"
where is the file ".profile" located?
Instructions
Files in the /etc directory below need to be edited as root, so use sudo nano filename
Enable I2C support
add i2c-dev to the end of /etc/modules
comment out (with a #) the line that says blacklist i2c-bcm2708 in /etc/modprobe.d/raspi-blacklist.conf
Enable the current user to access I2C hardware
install i2c-tools (includes i2cdetect and adds the i2c group) with: sudo apt-get update && sudo apt-get install i2c-tools
add the current user to the i2c group with: sudo adduser $USER i2c
Install the Quick2Wire Python API
install git with: sudo apt-get install git
download the API with: git clone https://github.com/quick2wire/quick2wire-python-api.git
Reboot to enable all the above changes
sudo reboot
Download and run the demo script
download it with: wget http://www.andrewscheller.co.uk/adc_demo.py
make it executable with: chmod +x adc_demo.py
run it with: ./adc_demo.py
If everything went well you should now find that you get:
1: 0.000000
by joan » Sun Oct 27, 2013 8:57 pm
~ is shorthand for the home directory of the user entering the command.
e.g. if your user name is pi then ~/.profile is in /home/pi/.profile
So you could nano ~/.profile or nano /home/pi/.profile to edit the file.
Note, files starting with a . (dot) are not listed by ls by default. To see such files use ls -a
by FTrevorGowen » Sun Oct 27, 2013 9:00 pm
"~/" is shorthand for your (ie. the current user's) home directory.
If "ls -laF ~/" doesn't list a (normally hidden) file with the name ".profile" you need to create a file with that name, and add the line "export PYTHONPATH=$PYTHONPATH:$HOME/quick2wire-python-api" into it as per the instructions eg. with nano like @joan suggested whilst I was typing this.
(NB: I don't use an "adc pi" myself, but have inferred the above from the info. you provided)
Trev.
Mainly running "Wheezy Raspbian" on eight Pi's (an A, B1, 2xB2, 2xB+, A+ and a P2B). Notes about them begin at http://www.cpmspectrepi.webspace.virginmedia.com/raspberry_pi/raspiidx.htm
by zenobi » Mon Oct 28, 2013 9:39 am
if i look in the folders i have something like : /home/pi/quick2wire-python-api
do i have to change also the text within te .profile?
or is "$HOME/quick2wire-python-api" the same as : /home/pi/quick2wire-python-api ?
THX
by joan » Mon Oct 28, 2013 11:52 am
zenobi wrote:if i look in the folders i have something like : /home/pi/quick2wire-python-api
THX
They should be the same. Something wrong if they are not.
Type
echo $HOME
from the command line to check.
