Review: Renesas Electronics USB 3.0 Hub
1 post
by tonaldo » Tue Mar 19, 2013 9:18 pm
Hi Community,
just bought this USB 3.0 Hub device from Sharkoon:
http://www.amazon.de/gp/product/B008PSL45Y/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
It uses the Renesas Electronics third Generation USB 3.0 Host Controller. It comes with a 5A power supply and has 4 Ports. I'm using it with a PI Model B and the latest Raspbian from the official site. So far so good, here are my test results:
I'm powering my PI over one of the ports. My Pi works very well running @950 Mhz. Under Raspbian, i think the device gets recognized, although Raspbian is not showing it's name. When i attach different usb-flash or hard-drives to the hub, they all work well (even my external WD MyPassport USB 3.0 ntfs-hd!). Unfortunately, the hub does not recognize any usb-keyboards or mice attached to it and only 3 of the 4 ports are working. Under Windows the hub works fine, so it's not a hardware issue.
Is this a kernel or configuration issue? Appreciate your help!
Here is an extract of lsusb -v:
Bus 001 Device 011: ID 2109:3431
Couldn't open device, some information will be missing
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0 Unused
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x2109
  idProduct          0x3431
  bcdDevice           42.47
  iManufacturer           0
  iProduct                1
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0001  1x 1 bytes
        bInterval              12
BTW, I love my Pi (using it mainly as a LAMP development server for my coding and xbmc of course!)! Back to the roots... i feel like in my old Commodore 64 days;)
Greetings from Germany
tonaldo
