Slow playback on XBMC 720p and 1080p
by free2air » Wed Jan 09, 2013 1:53 pm
Hello guys,
I bought a Raspberry PI 512 ram version, It has Raspbian installed with XBMC.
When I try to play mkv videos from a network share or a DLNA server it hangs from 5 to 10 seconds and I don't know why.
I have a smart Samsung TV which has a DLNA client that works perfectly.
Can you tell me please what settings should I do, what should I modify.
Thanks a lot.
Regards,
Raspberry PI 512MB ram
by ski522 » Wed Jan 09, 2013 4:29 pm
try playing the movie from a shell prompt using omxplayer to see if the same problem occurs.
by NewPi » Thu Jan 17, 2013 12:31 pm
Have you tried updating your firmware using rpi-update, the latest firmware update has a fix for USB stack which could be an issue with high-load when accessing disk and high network load.
Raspberry Pi Howto, Tips, Tricks and Tools -> http://bit.ly/RPiTricks
by topguy » Thu Jan 17, 2013 12:39 pm
free2air wrote:Hello guys,
What do you mean by "it hangs from 5 to 10 seconds" ? Describe the behavior more exact ?
