Berryboot Headless Install
by bablu_boy » Mon Dec 24, 2012 2:17 am
hi,
I do not have a monitor attached to my Raspberry Pi and trying to do a headless install with Berryboot. I added the vnc install option to the cmdline.txt before copy the berryboot files to the SD Cards.
The contents of the cmdline.txt looks like this:
quiet bootmenutimeout=10
vncinstall
After switching on the Pi, I can see that it has obtained a IP from my router (using nmap scan) and can ping it as well.
however when I try to vnc into it from my ubuntu desktop using:
xtightvncviewer 192.168.1.6:0
I get the following:
xtightvncviewer: ConnectToTcpAddr: connect: Connection refused
Unable to connect to VNC server
sid@sid-NC10:~/Downloads$
I have tried VNC ports of 0 and 1, but still the same issue.
Appreciate help on how I can see the Berryboot options and complete the installation remotely.
Many thanks in advance.
by Max » Mon Dec 24, 2012 12:55 pm
bablu_boy wrote:The contents of the cmdline.txt looks like this:
vncinstall
cmdline.txt options must be on a single line (as opposed to the stuff in config.txt).
by bablu_boy » Mon Dec 24, 2012 1:14 pm
vncinstall
OK. Will try that. However what is the delimiter between the options on the single line. Is the below ok for cmdline.txt?
quiet bootmenutimeout=10;vncinstall
many thanks.
by Max » Mon Dec 24, 2012 1:16 pm
bablu_boy wrote:OK. Will try that. However what is the delimiter between the options on the single line.
Spaces
"quiet" and "bootmenutimeout=10" are two separate options.
