Raspbian Screensaver
by Ann3x » Sun Sep 23, 2012 9:43 am
Hi Everyone,
I'm building a digital photoframe based on an RPi to pull from a flickr account (build log will come once I have it working) but having some issues with settin up my Pi (mainly due to my lack of linux skills I think).
Hoping I can get some advice :), it seems such a basic issue that I expect I'm missing something fundamental. This is where I'm at:
  • Hardware built and running
  • Pi running at correct resolution and screen mode
  • Raspbian installed and update and configured to boot to desktop
  • Wirelss networking configured with putty and VNC remote access
and this is what I have left to do:
The annoying thing I'm stuck at is the seemingly simple task of disabling the screensaver!! I've read countless items on how to do this and have a script (named screensaveroff) working which looks like:
#! /bin/bash
# /etc/init.d/screensaveroff
xset s off
xset -dpms
xset s noblank
This script is owned by root and is executable. When I run it manually from terminal xset -q shows that the script has executed sucessfully and options are set. The issue is that try as I might I cannot get it to execute at boot/login. Ive tried the following (from various guides):
  • Calling my script from /etc/rc.local using the line:
    su -c "/etc/init.d/screensaveroff"
  • Running the code from my screensaveroff script directly from /etc/rc.local
  • Running screensaveroff using cron every one second (a messy way but just a test).
  • Running screensaveroff using cron @reboot command
  • Running screensaveroff via a call from .xinitrc (created in my home dir) as:
    xset s off
    xset -dpms
    xset s noblank
    exec /etc/alternatives/x-session-manager
None of these has any effect. Unless I run my script manually, screensaver options are still at default. To be honest, I'm getting really frustrated now, really how hard should it be to turn a screensaver off? Can anyone help? What's going wrong?
Thanks,
Rob
by Ann3x » Sun Sep 23, 2012 4:40 pm
I forgot, also tried adding the script to startup using:
sudo update-rc.d screensaveroff defaults
by Foggy » Sun Sep 23, 2012 6:25 pm
Please look at
viewtopic.php?f=66&t=18200&p=180271#p180271
Best wishes.
James.
by Ann3x » Sun Sep 23, 2012 8:00 pm
Hi James,
Thanks for the tip but, this doesn't seem to do anything on my install. Isnt it just changing the console screen options (ie not the desktop)?
Unfortunately my screen blanks as per normal :(.
Rob
by Ann3x » Mon Sep 24, 2012 2:13 pm
Really, noone else has had issues with running scripts automatically?
Ive checked the cron output and the echo is there, so the script *may* be running. Perhaps its permissions? Ive set owner to root and I though startup scripts (from /etc/rc.local) always got executed as root anyway.
Please people, any advice would be really appreciated. I can't believe it is this painful to just turn a screensaver off.
by Ann3x » Wed Sep 26, 2012 10:01 pm
Disappointing that noone on this forum can tell me how to run a script at login :(.
Seems ridiculous that a project is stopped due to the inability to turn a simple screensaver off but tbh, for a photo frame its actually a critical thing.
Really noone at all has any suggestions?
by RandomGuy92 » Tue Oct 02, 2012 3:33 pm
try adding it to the file /etc/xdg/lxsession/LXDE/autostart
ensure the it is on a new line, and the line starts with @
by series8217 » Tue Oct 16, 2012 3:16 pm
Ann3x, did you look at the LXDE documentation? You can use the autostart feature to have programs start after the X session loads.
https://wiki.archlinux.org/index.php/LX ... t_Programs
You need to make a .desktop file for the program/script you want to run, or find the location of the .desktop file if the program already has one.
The format of a basic .desktop file is:
[Desktop Entry]
Type=Application
Exec=scriptname
Name=My Script
Once you have found or created the .desktop file, place it (or create a symlink to it) in ~/.config/autostart.
By default it should be enabled on startup once you have placed the .desktop file there. You can turn it on and off with the lxsession-edit utility.
by alexbain » Tue Jan 08, 2013 1:26 am
To disable the screensaver (and the screen from blanking) I had to make the following change:
Edit /etc/lightdm/lightdm.conf and add this line under the '[SeatDefaults]' section:
xserver-command=X -s 0 dpms
Hope that helps!
by forkd » Tue Jan 22, 2013 4:37 am
Hi, for the xset commands to work you neecd to install x11 server utilities....
I believe the command is
sudo apt-get install x11-server-utils
I am also using a raspberry pi as a digital picture frame :)
