rpi USB limited to 15 ports?
by elatllat » Tue Aug 07, 2012 4:26 pm
All of the ports on my USB hubs work on my x86.
Only the first 15 work on the rpi.
The rpi is connected to a 7-port-hub which is connected to a 10-port-hub.
dmesg for 16+:
[ 1071.682998] usb 1-1.3.1.1.4: new high speed USB device number 7 using dwc_otg
[ 1071.785001] usb 1-1.3.1.1.4: New USB device found, idVendor=13fd, idProduct=1340
[ 1071.785049] usb 1-1.3.1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1071.785071] usb 1-1.3.1.1.4: Product: FANTOM DRIVE
[ 1071.785087] usb 1-1.3.1.1.4: Manufacturer: MICRONET
[ 1071.785102] usb 1-1.3.1.1.4: SerialNumber: blabla
[ 1071.795097] usb 1-1.3.1.1.4: can't set config #1, error -71
dmesg for 15-:
[ 1226.176894] usb 1-1.3.1.7: new high speed USB device number 13 using dwc_otg
[ 1226.278388] usb 1-1.3.1.7: New USB device found, idVendor=13fd, idProduct=1340
[ 1226.278436] usb 1-1.3.1.7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1226.278458] usb 1-1.3.1.7: Product: FANTOM DRIVE
[ 1226.278473] usb 1-1.3.1.7: Manufacturer: MICRONET
[ 1226.278488] usb 1-1.3.1.7: SerialNumber: blabla
[ 1226.293803] scsi5 : usb-storage 1-1.3.1.7:1.0
[ 1227.297710] scsi 5:0:0:0: Direct-Access     MICRONET FANTOM DRIVE     2.10 PQ: 0 ANSI: 4
[ 1227.299488] sd 5:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 1227.300641] sd 5:0:0:0: [sda] Write Protect is off
[ 1227.300693] sd 5:0:0:0: [sda] Mode Sense: 21 00 00 00
[ 1227.301886] sd 5:0:0:0: [sda] No Caching mode page present
[ 1227.301934] sd 5:0:0:0: [sda] Assuming drive cache: write through
[ 1227.306118] sd 5:0:0:0: [sda] No Caching mode page present
[ 1227.306169] sd 5:0:0:0: [sda] Assuming drive cache: write through
[ 1227.319576]  sda: sda1
[ 1227.325733] sd 5:0:0:0: [sda] No Caching mode page present
[ 1227.325784] sd 5:0:0:0: [sda] Assuming drive cache: write through
[ 1227.325809] sd 5:0:0:0: [sda] Attached SCSI disk
Notably 2^4=16.
Can anyone reproduce this problem or use more than 15 USB ports?
by jbeale » Tue Aug 07, 2012 4:34 pm
I haven't tried attaching that many ports, so I can't say if there's a software issue with > 15 ports. However, are you using externally powered hubs? If not, there could also be a problem with the low (100 mA) current available from the R-Pi USB host ports.
I do have a cheap 10-port hub I could try, although I believe internally it is two devices, a 4-port hub of which one output goes to a 7-port hub (or maybe the reverse). So it might be that you are crossing an internal dividing line between two sub-hubs in your 10-port device.
by elatllat » Tue Aug 07, 2012 4:45 pm
Hi jbeale,
Thanks for bringing that up.
Yes the hubs are externally powered, so is the external drive.
If it were a power problem it would matter how many drives I plugged in not where I plugged in a single drive.
So I'm confidant we can rule out power problems.
It seems more likely to me that usb drivers address space is limited to a byte or half.
by jbeale » Wed Aug 08, 2012 4:31 am
Ok, I tried connecting a 10-port hub, and also several 4-port hubs (powered separately from the Pi, with isolated-power USB cables so there's no power feedback either). My observation is that I cannot use any daisy-chained hub. That is, a 4-port hub connected to one of the ports on another 4-port hub does not work. Also, error messages in dmesg show up when the secondary hub is connected. My 10-port hub is internally configured as a 7+4 port hub. The first 6 ports work, and the other 4 ports (which are on the secondary hub internally) do not.
So let me pose this question: has anyone successfully daisy-chained two or more hubs from the R-Pi? A quick google search seems to give me (a) entirely theoretical discussions, and (b) people trying this without success.
dmesg output when connecting the 10-port hub:
[ 4290.893707] usb 1-1.3: new high speed USB device number 25 using dwc_otg
[ 4290.995334] usb 1-1.3: New USB device found, idVendor=1a40, idProduct=0201
[ 4290.995426] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4290.995504] usb 1-1.3: Product: USB 2.0 Hub [MTT]
[ 4291.015584] hub 1-1.3:1.0: USB hub found
[ 4291.015995] hub 1-1.3:1.0: 7 ports detected
[ 4291.303693] usb 1-1.3.1: new high speed USB device number 26 using dwc_otg
[ 4291.406258] usb 1-1.3.1: New USB device found, idVendor=1a40, idProduct=0101
[ 4291.406347] usb 1-1.3.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4291.406417] usb 1-1.3.1: Product: USB 2.0 Hub
[ 4291.422769] hub 1-1.3.1:1.0: USB hub found
[ 4291.433717] hub 1-1.3.1:1.0: 4 ports detected
[ 4291.535242] INFO:: periodic_channel_available: Total channels: 8, Periodic: 5, Non-periodic: 3
[ 4291.535259]
[ 4291.535280] INFO:: schedule_periodic: No host channel available for periodic transfer.
[ 4291.535292]
[ 4291.535370] ERROR::dwc_otg_hcd_urb_enqueue:518: DWC OTG HCD URB Enqueue failed adding QTD. Error status -4008
[ 4291.535384]
[ 4291.535562] hub 1-1.3.1:1.0: activate --> -4008
by jackokring » Wed Aug 08, 2012 4:52 am
This appears as a software issue, and may effect some single devices with internal multifunction. I haven't tried. I think it's maybe a fixed size array in the USB driver. Assuming self powered hubs of course ...
Cheers Jacko
Pi=B256R0USB CL4SD8GB Raspbian Stock. https://sites.google.com/site/rubikcompression/strictly-long https://dl.dropboxusercontent.com/u/1615413/Own%20Work/Leptronics.pdf https://groups.google.com/forum/#!topic/comp.compression/t22ct_BKi9w
by elatllat » Wed Aug 08, 2012 7:53 am
jbeale wrote:...has anyone successfully daisy-chained two or more hubs from the R-Pi?...
As indirectly stated in my OP I can get 6 of a 10-port-hub daisy-chained off a 7-port-hub working.
jbeale wrote:...My 10-port hub is internally configured as a 7+4 port hub...
So maybe only some types of hubs are daisy-chainedable with the rpi, or maybe there is a max depth. My 10-port-hub is also a 7+4:
cat /var/log/kern.log |grep "] hub"
Aug  5 23:01:19 raspbian kernel: [    3.266071] hub 1-0:1.0: USB hub found
Aug  5 23:01:19 raspbian kernel: [    3.272652] hub 1-0:1.0: 1 port detected
Aug  5 23:01:19 raspbian kernel: [    3.938399] hub 1-1:1.0: USB hub found
Aug  5 23:01:19 raspbian kernel: [    3.945373] hub 1-1:1.0: 3 ports detected
Aug  5 23:01:19 raspbian kernel: [    4.709066] hub 1-1.3:1.0: USB hub found
Aug  5 23:01:19 raspbian kernel: [    4.717682] hub 1-1.3:1.0: 7 ports detected
Aug  5 23:01:19 raspbian kernel: [    5.194829] hub 1-1.3.1:1.0: USB hub found
Aug  5 23:01:19 raspbian kernel: [    5.202637] hub 1-1.3.1:1.0: 7 ports detected
Aug  5 23:01:19 raspbian kernel: [    9.629203] hub 1-1.3.1.1:1.0: USB hub found
Aug  5 23:01:19 raspbian kernel: [    9.639018] hub 1-1.3.1.1:1.0: 4 ports detected
Aug  5 23:04:56 raspbian kernel: [  245.865225] hub 1-1.3.1.1:1.0: unable to enumerate USB device on port 4
by jbeale » Wed Aug 08, 2012 11:16 pm
According to this post, you are limited to a total of 8 hub ports in the USB driver:
viewtopic.php?f=28&t=12097&p=145278#p145479
Also note that there is a deficiency in the driver which means we're limited currently to a maximum of 8 periodic endpoints, this is because the driver reserves a channel (of which there are eight) for each periodic endpoint. Now I believe that for each hub port you have at least one interrupt endpoint so once you get to seven hub ports then you run out of channels!
by elatllat » Thu Aug 09, 2012 7:49 pm
As I noted in that thread you can add hubs until this number hits 7:
lsusb -v | grep -iP "Transfer Type.*(Interrupt|Isochronous)" | wc -l
After that, hubs won't work.
(That is about 2 hubs with 7 ports each assuming they are not internally split)
by Stric » Wed Aug 15, 2012 9:37 pm
My WiFi dongle (TP-Link TL-WN721N) eats 2 channels and a Logitech C270 HD Webcam eats a whopping 16. Right now my rpi shows 23 when these two are connected to a 4p genesys based hub. Given previous information, I might not be surprised that wifi gets randomly non-worky when taking snapshots with the webcam.
Is there a way to fix this?
by dom » Wed Aug 15, 2012 11:03 pm
Stric wrote:My WiFi dongle (TP-Link TL-WN721N) eats 2 channels and a Logitech C270 HD Webcam eats a whopping 16. Right now my rpi shows 23 when these two are connected to a 4p genesys based hub. Given previous information, I might not be surprised that wifi gets randomly non-worky when taking snapshots with the webcam.
If you are getting "INFO:: schedule_periodic: No host channel available for periodic transfer." then there is a source code patch available (from one of the github issues) that seems to help this case.
I need to merge the code in, in a way that it can be easily switched on and off (e.g. module parameter) so more people can test it.
by jweob » Wed Aug 22, 2012 2:27 am
Hi Dom
I have this issue as well - my webcam stops working after a short time and when check dmesg I get the error messages below. The webcam is plugged into a four port USB hub. The other devices on the hub are a wifi dongle and a lego mindstorms brick.
I checked github for the patch you mentioned but couldn't find the right one. Can you provide any more information on which patch I need to use (hints on installation would be great too!).
Thanks!
[ 506.559820] INFO:: periodic_channel_available: Total channels: 8, Periodic: 4, Non-periodic: 4
[ 506.559837]
[ 506.559859] INFO:: schedule_periodic: No host channel available for periodic transfer.
[ 506.559870]
[ 506.560053] ERROR::dwc_otg_hcd_urb_enqueue:518: DWC OTG HCD URB Enqueue failed adding QTD. Error status -4008
[ 506.560067]
[ 506.560089] uvcvideo: Failed to submit URB 0 (-4008).
by dom » Wed Aug 22, 2012 9:09 am
jweob wrote:I checked github for the patch you mentioned but couldn't find the right one. Can you provide any more information on which patch I need to use (hints on installation would be great too!).
Update to latest firmware (e.g. with rpi-update). Add
microframe_schedule=1
to cmdline.txt
by jweob » Thu Aug 23, 2012 3:29 am
Thank you very much for the quick reply! Unfortunately I still get the same problem. I have used rpi_update following the instructions on https://github.com/Hexxeh/rpi-update and then added the text to commandline.txt in the boot directory so that commandline.txt now reads:
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 $
smsc95xx.turbo_mode=N
When I run the webcam it works for a few minutes then it stops. I check dmesg and see:
[ 165.799645] smsc95xx 1-1.1:1.0: eth0: Failed to read register index 0x00000114
[ 476.758782] smsc95xx 1-1.1:1.0: eth0: Failed to read register index 0x00000114
[ 963.005308] smsc95xx 1-1.1:1.0: eth0: Failed to read register index 0x00000118
[ 977.846275] INFO:: periodic_channel_available: Total channels: 8, Periodic: 4, Non-periodic: 4
[ 977.846292]
[ 977.846316] INFO:: schedule_periodic: No host channel available for periodic transfer.
[ 977.846326]
[ 977.849486] ERROR::dwc_otg_hcd_urb_enqueue:518: DWC OTG HCD URB Enqueue failed adding QTD. Error status -4008
[ 977.849502]
[ 977.849606] uvcvideo: Failed to submit URB 0 (-4008).
The smsc95xx error didn't start appearing until I added "smsc95xx.turbo_mode=N". This was following advice in another thread on how to stop the pi from crashing under load.
Any ideas what I'm doing wrong?
Thanks again!
by kg001 » Thu Aug 23, 2012 4:16 am
I am interested to see if you have similar issues to me. Can you constantly ping your PI from another machine? & let me know what happens to the ping time when the webcam fails. My ping times go from 0.3ms at the command line to 500ms to 1000ms with a desktop environment open then to 3000ms+, once I am actively using anything from the desktop, at that point things start dropping off external connections.
by fbutler » Thu Aug 23, 2012 7:00 am
Thanks again!
It looks like you have added the additional options as separate lines in cmdline.txt. They need to be appended to the first line instead
by jweob » Thu Aug 23, 2012 11:02 am
Thanks fbutler! I have put the options at the end of the line instead so my cmdline.txt looks like this:
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait smsc95xx.turbo_mode=N microframe_schedule=1
However I still get the same problem. Webcam stops, dmesg reads:
[ 38.779457] wlan0: no IPv6 routers present
[ 111.370517] INFO:: periodic_channel_available: Total channels: 8, Periodic: 4 , Non-periodic: 4
[ 111.370533]
[ 111.370556] INFO:: schedule_periodic: No host channel available for periodic transfer.
[ 111.370567]
[ 111.370901] ERROR::dwc_otg_hcd_urb_enqueue:518: DWC OTG HCD URB Enqueue faile d adding QTD. Error status -4008
[ 111.370915]
[ 111.370939] uvcvideo: Failed to submit URB 0 (-4008).
[ 241.260876] smsc95xx 1-1.1:1.0: eth0: Failed to read register index 0x0000011 4
Any ideas?
@kg001 I am able to ping my pi consistently, but I am just using the CLI over SSH. Ping is usually 1-5ms, occasionally as long as 200 ms but only once or twice.
by kg001 » Thu Aug 23, 2012 6:51 pm
Thanks for the info looks like the issue i'm having is not related Running my CLI via SSH as well incidentally.
Cheers KG001
by fbutler » Thu Aug 23, 2012 7:46 pm
jweob wrote:Thanks fbutler! I have put the options at the end of the line instead so my cmdline.txt looks like this:
Perhaps a silly question. Did you reboot the Pi after you made the change and before testing?
by dom » Thu Aug 23, 2012 11:59 pm
Should be:
dwc_otg.microframe_schedule=1
by jweob » Fri Aug 24, 2012 2:23 am
Thanks for the help. I have made the edit and rebooted but still get the error. Webcam runs for about 2 mins then I get the same error. Sorry to keep asking you on this, what should I try next? :oops:
cmdline.txt
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait smsc95xx.turbo_mode=N dwc_otg.microframe_schedule=1
dmesg
[ 1214.197366] INFO:: periodic_channel_available: Total channels: 8, Periodic: 4, Non-periodic: 4
[ 1214.197383]
[ 1214.197406] INFO:: schedule_periodic: No host channel available for periodic transfer.
[ 1214.197416]
[ 1214.197618] ERROR::dwc_otg_hcd_urb_enqueue:518: DWC OTG HCD URB Enqueue failed adding QTD. Error status -4008
[ 1214.197633]
[ 1214.197654] uvcvideo: Failed to submit URB 0 (-4008).
by dom » Fri Aug 24, 2012 9:22 am
jweob wrote:Thanks for the help. I have made the edit and rebooted but still get the error. Webcam runs for about 2 mins then I get the same error. Sorry to keep asking you on this, what should I try next? :oops:
cmdline.txt
I assume thereisn't a new line in cmdline.txt?
Can you report output of:
uname -a
by samsamsam » Fri Aug 24, 2012 11:58 am
I had similar problem. When I put
The parameter dwc_otg.microframe_schedule=1 not working, but when I set:
dwc_otg.microframe_schedule=1 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait smsc95xx.turbo_mode=N
It's works very well.
by jweob » Fri Aug 24, 2012 3:02 pm
Sorry - your original solution did work. When I did uname -a I saw that I had version 3.1.9. I did the update a few weeks ago and didn't realise there had been a firmware update since then. Rerunning rpi-update fixes the issue, webcam can now run indefinitely
Thanks for all the help!
