Icons and Text are too Big
by ebird97 » Wed Oct 31, 2012 3:39 am
Everything is very large, my screen is 20 inches and the letter "E" is the size of my thumbnail!
Also, when I try opening the Arduino IDE the top and bottom of the window are out of the screen so I can't resize it and use it normally.
I've tried modifying the config.txt file and this did not address the problems mentioned above. I forced the screen resolution to my real resolution and this didn't produce any differences.
Here's my config.txt file if it helps =>
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
framebuffer_width=640
framebuffer_height=480
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=1
hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# for more options see http://elinux.org/RPi_config.txt
Thank You I appreciate any help a ton!
by billb » Wed Oct 31, 2012 3:58 am
Are you connecting to the display using HDMI? You're telling it to use VGA (640x480) which is a low resolution.
You probably need to comment out these lines (add a # to the beginning of each line):
hdmi_group=1
hdmi_mode=1
by ebird97 » Wed Oct 31, 2012 4:00 am
Yes, I'm using the HDMI port on my Raspberry pi but I'm using a HDMI to VGA converter because my display is a VGA display.
by billb » Wed Oct 31, 2012 4:12 am
Ah ... there's what is referred to as a VGA connector and there is what is referred to as VGA resolution, which is 640x480. However, just because you're using a VGA connection that doesn't necessarily mean you need to use VGA resolution. Unless your display really is limited to 640x480, which would be odd.
You mentioned you have a 20" screen, but I don't know if it's widescreen or 4:3. You probably want to use something like 1024x768 or 1280x1024 if it's 4:3 (non-widescreen).
by ebird97 » Tue Nov 06, 2012 10:43 pm
Thank you so much! I finally got everything working.
