Screen Resolution
by spamurai » Thu Jun 28, 2012 9:51 pm
I'm having trouble with my screen resolution.
I've been through loads and loads of threads but still can not find a solution.
As i'm a beginner, maybe i'm doing something stupid, i don't know.
My Tv is 1920x1080i.
I've fixed the overscan so it fits my screen properly. I did that in the "sudo nano /boot/config.txt".
However, my txt is a tiny bit too small and slightly blurry, i'm assuming its the resolution.
Looking on the RPi Config file page, i can not see a group/mode that is suitable for my screen resolution.
I've tried a few that i thought were logical choices, but still looks the same :(
(I've even had to put the SD card in my mac to remove a certain mode as after the reboot it wouldn't even boot up again. I guessing it didn't like the hdmi mode :lol: )
Anyone else had this problem or know how to fix it?
I can't really do anything as it is because after 30mins of using it the text gives me a headache :roll:
There are 10 types of people in the world. Those that understand binary and those that don't!
01101000 01100001 01101000 01100001
by dom » Thu Jun 28, 2012 10:33 pm
/opt/vc/bin/tvservice -m CEA
/opt/vc/bin/tvservice -m DMT
Will list the supported resolutions.
720p60 is pretty widely supported, so would be a good choice.
hdmi_group=1
hdmi_mode=4
(from http://elinux.org/RPi_config.txt)
by spamurai » Thu Jun 28, 2012 10:43 pm
dom wrote:/opt/vc/bin/tvservice -m CEA
hdmi_group=1
hdmi_mode=4
Yeh i've been trying many different ones from both CEA and DMT.
Do you know what the difference is between the two?
group 1 mode 4 is not supported.
I'm assuming i should stick to 60Hz if thats what the TV's default is?
The only ones my TV support @ 60Hz are:
1) Group 1 Mode 5 (1920x1080) interlaced
2) Group 1 Mode 16 (1920x1080) progressive
3) Group 2 Mode 16 (1024x768) progressive
And whats the difference between interlaced and progressive?
1) and 2) are too small and 3) is too big :cry:
by dom » Thu Jun 28, 2012 11:07 pm
Progressive is better than interlaced (interlaced alternates displaying odd and even lines each frame, and tends to be more flickery).
Use 1080 progressive and add:
framebuffer_width=1280
framebuffer_height=720
by spamurai » Thu Jun 28, 2012 11:36 pm
dom wrote:Progressive is better than interlaced (interlaced alternates displaying odd and even lines each frame, and tends to be more flickery).
Awesome, thats handy to know. Thanks.
I used overscan_left=-20 etc. Is that the same as frame buffer?
