trouble installing ucb logo
by NikoBelic » Fri Jun 29, 2012 12:38 am
Hello, I'm trying to install UCB logo on my pi. I retrieved the 'complete distribution archive for Unix/Linux' from the liink at http://www.cs.berkeley.edu/~bh/logo.html, but when I followed the instructions I got an error (could try running again to tell you this, but its a bit of typing and I'm hoping someone else has tried this and knows what to do to get it to work). I'm runnig the debian wheezy mix. Thanks for any help.
by mahjongg » Fri Jun 29, 2012 12:43 am
Are you sure the version you are trying to install is compiled for ARM, and not for x86 (intel processors)?
If you have the source code you can compile it for the correct CPU architecture yourself (ARM6 in case of the R-PI)
by andyl » Fri Jun 29, 2012 8:12 am
Are you compiling from source?
BTW you can capture all the output from the build process by using redirection
make > ~/make.txt 2>&1
will put the output in make.txt in your home directory - you can then open that with an editor and copy the error line into your post here.
If you want to capture a protracted session of commands to a file use script. man script for more info.
by ukscone » Fri Jun 29, 2012 11:15 pm
ucb logo works ok
the error you get is probably about missing -lbsd
just edit the makefile and remove -lbsd from the LIBS= line
by NikoBelic » Sat Jun 30, 2012 9:27 am
Thanks everyone, I tried the changes ukscone suggested (delete .lbsd from makefile); seems to help but I now get the following error:
pi@raspberrypi ~/ucblogo/ucblogo-6.0 $ make
gcc -g -O -O0 -DUSE_OLD_TTY -c -o graphics.o graphics.c
In file included from graphics.c:41:0:
xgraphics.h:4:22: fatal error: X11/Xlib.h: No such file or directory
compilation terminated.
make: *** [graphics.o] Error 1
Is there a similar fix for this? Best wishes.
by andyl » Sat Jun 30, 2012 9:33 am
NikoBelic wrote:Thanks everyone, I tried the changes ukscone suggested (delete .lbsd from makefile); seems to help but I now get the following error:
OK sounds like you haven't got the X11 dev support (the include files) installed.
sudo apt-get install libx11-dev
You might need other bits and bobs installed.
