Can't log into the Root Terminal or install anything.
by TheLog » Sun Jun 24, 2012 8:39 pm
I am using the Debian “squeeze” and have done nothing on it except change the time, date, and re-size my SD card.I cant seem to log into the root terminal.(I tried the password given on the download link) I was trying to change the username and the password for Pi. I also tried to install Adobe Flash Player and Google Chrome. I don't know about the compatibility between Debian and Google Chrome. The installion file for Google Chrome was able to download on to the computer but the Flash Player could not. There are multiple types of Flash and I tried all of them and it still did not download. Is there something I am doing wrong? Also it would be helpful if anyone could tell me how to change the username and password.
Please help and thank you. :D
by alexeames » Sun Jun 24, 2012 9:01 pm
The Pi doesn't yet do flash, although ISTR someone mentioned something about a plugin for chromium but that might be a figment of my imagination.
You can use sudo to do pretty much anything root user would do though
Alex Eames RasPi.TV HDMIPi.com RasP.iO
by TheLog » Sun Jun 24, 2012 9:15 pm
So is there anything that is like flash the Pi supports?
by alexeames » Sun Jun 24, 2012 9:35 pm
Since you can only log in as pi, you can't modify user pi when logged in as pi, but you can use your sudo priviliges to create a new user
sudo adduser newusername
then it'll ask you for a password twice
Then you'll need to add it to the sudoers group with
sudo visudo
Then copy the entry for pi changing it to your new id
then writeout (CTRL + O)
<enter>
CTRL + X to exit
Then make sure logging in with the new ID works and you have sudo powers.
Then you can remove the pi user if you want.
sudo deluser pi
but if you want to remove the /home/pi directory you can use
sudo deluser -remove-home pi
You'll have to go back into the sudoers file to remove pi as well.
by AndrewS » Mon Jun 25, 2012 1:50 pm
by bredman » Mon Jun 25, 2012 10:21 pm
Here are the instructions to install the Chromium browser.
http://elinux.org/RPi_Chromium
You do not need to create a new user or be a root user to install software.
