timeout in locking authority file /home/pi/.Xauthority
by theholychilli » Sun Apr 28, 2013 6:09 pm
so I have just been following this tutorial: http://www.instructables.com/id/Bluetoo ... spberry-Pi
I've done everything up to step 3, because when I reboot my Raspberry Pi, it just says:
xauth: timeout in locking authority file /home/pi/.Xauthority
Then it goes black for a few minutes and then it comes up with "No protocol specified" all the way down the screen, then:
xinit: giving up
xinit: unable to connect to X server: Resource temporarily unavailable
waiting for X server to shut down Server terminated successfully (0). Closing log file.
xinit: server error
I'm running Debian and have all the latest upgrades and updates.
Any help would be awesome.
by tvoverbeek » Sun Apr 28, 2013 6:21 pm
Step 3 installs a vnc server in case you do not have a display connected to your Pi.
My guess is that you already have a X server running on display :0, hence when the vncserver
tries to access display :0 it fails.
In step 3 try to change 'vncserver :0 -geometry 1920x1080 -depth 24' to
'vncserver :1 -geometry 1920x1080 -depth 24'.
This gives the vncserver its own display and X server which does not conflict with the other one.
Hope this helps.
Ton
by theholychilli » Sun Apr 28, 2013 6:50 pm
Thanks, this helped a lot. :D
by theholychilli » Sun Apr 28, 2013 7:22 pm
Is there any way I can disable it?
by tvoverbeek » Sun Apr 28, 2013 7:58 pm
I assume you mean disabling the original X server running on display :0.
If you are using Raspbian just run raspi-config and under the 'boot behaviour' topic
select to *not* boot to the desktop.
This will delete starting the X server and the window manager at boot time.
Ton
by theholychilli » Sun Apr 28, 2013 8:12 pm
Ok, so I've done that, and it comes up with login and password, but whenever I enter those in, it goes black for a few seconds, then goes back onto that screen.
yeah i think ive screwed everything up
I'm a complete noob at this. :lol:
by theholychilli » Sun Apr 28, 2013 8:22 pm
Ok this is really annoying me now! :evil:
