Usb memory drive mounts as read-only file system
by Harrowed » Mon Aug 27, 2012 8:21 pm
I have problem with my usb memory drive mounting as read-only file system (even for the owner). How to change this?
by elatllat » Mon Aug 27, 2012 11:39 pm
mount -n -o remount,rw /your/mount/point
How are you mounting it?
What's the output of
mount
by Harrowed » Tue Aug 28, 2012 8:06 am
pi@raspberrypi ~ $ sudo mount -n -o remount,rw /home/pi/Mohikaani
mount: warning: /home/pi/Mohikaani seems to be mounted read-only.
I'm mounting with this script:
#! /bin/sh
# /etc/init.d/mountdisk
sudo mount -o uid=pi,gid=pi /dev/sda1 /home/pi/Mohikaani
exit 0
I also tried without that script and even automatic mount to the media folder happens as read-only.
by RaTTuS » Tue Aug 28, 2012 8:09 am
check the filesystem of the drive
i.e.
fsck.ext4 [or whatever] /dev/sda1
http://www.catb.org/esr/faqs/smart-questions.html Ask Questions
http://www.raspberrypi.org/forums/viewtopic.php?f=29&t=7192 AutoStart Script
"That's not right, the badgers have moved the goalposts."
by Harrowed » Tue Aug 28, 2012 8:50 am
The file system is ntfs because it was used with Windows before (and still is every now and then) and there's 1,5 TB used so the file system change would be pretty burdensome. It worked before.
So here's the output with ntfsfix from ntfs-3g suite.
pi@raspberrypi ~ $ sudo ntfsfix /dev/sda1
Mounting volume... OK
Processing of $MFT and $MFTMirr completed successfully.
Checking the alternate boot sector... OK
NTFS volume version is 3.1.
NTFS partition /dev/sda1 was processed successfully.
by Harrowed » Tue Aug 28, 2012 9:05 am
Oh, now it works after 10th reboot. I can see what ya did there Mr. USB-Drive.
by Harrowed » Sat Sep 01, 2012 9:00 am
Ok, the problem is back and rebooting doesn't help. Any ideas?
by bestie » Wed Nov 14, 2012 6:36 pm
I've had a similar problem, it turned out the file system on my USB stick was being corrupted by NZBGet so every time I started it the stick would go read-only. Once I repaired the file system it was fine.
Hope that helps someone.
by Noar » Thu Nov 15, 2012 9:38 am
Maybe comming from unclean disconnection from windows box. For me, ntfs-3g did the trick.
sudo apt-get install ntfs-3g
by Rad77 » Sat Dec 29, 2012 9:57 am
Also had the same problem and that fix (install ntfs-3g) worked for me - Thanks!
Now mounted just fine using...
sudo mount -t ntfs-3g -o uid=pi,gid=pi /dev/sda1 /media/WD250/
by jfornango » Mon Dec 31, 2012 9:02 pm
Just one more reason for the world to go NFS. :lol:
I'm only wearing black until they find something darker.
by cats_five » Fri Jan 11, 2013 10:12 am
I had exactly the same problem and using ntfs-3g fixed it, but I didn't realise at first I needed to install something extra to do this.
Anyway that means a PC could read what's on my external HDD and I've not had to reformat it all of which is Good.
by xfear238 » Thu Aug 15, 2013 10:17 am
Use this command first to install ntfs-3g on your raspberry pi :
sudo apt-get install fuse ntfs-3g
sudo mount -t ntfs-3g /dev/sda1 /media/2TO/
It works !
by russellhoff » Wed Dec 18, 2013 5:03 pm
You should try mounting devices with Fstab. It's properlier to do with it rather than using any other script. It's also very simple.
$ leafpad /etc/fstab
Then add a line similarly as the one you wrote in the script.
Check out wikipedia's fstab page.
