Are there any (simple) guides to setting up AirPrint?
by sbaratheon » Fri Oct 05, 2012 5:23 pm
Does anyone have a beginner guide to setting up AirPrint on the Pi which definitely works?
Thanks!
by FrozenBrain » Fri Oct 05, 2012 8:47 pm
As far as I know, installing cups (via "sudo apt-get install cups") and setting up your printer via the webinterface should be enough. There is a guide at http://rohankapoor.com/2012/06/configur ... nt-server/ that does the same thing. However the author also installs Avahi which is no longer needed I think.
by sbaratheon » Fri Oct 05, 2012 10:22 pm
Ah, I've almost got it working but it only seems to work through the router and not the extender ( the extender works perfectly for everything else and I can ping the raspberry pi etc). Any ideas?
by vladimircezar » Tue Nov 06, 2012 8:01 pm
