login
by tonycarney » Fri Jun 08, 2012 6:04 pm
Hi i am new to the rasperrypi
at the moment the screen is asking for a password
i have tried the default but no success can any one help
by abishur » Fri Jun 08, 2012 6:13 pm
which distro are you using?
Dear forum: Play nice ;-)
by tonycarney » Fri Jun 08, 2012 8:30 pm
tonycarney wrote:Hi i am new to the rasperrypi
i am using debian6-19-04-2012
by rusky » Fri Jun 08, 2012 10:06 pm
Log in using
user: pi
Password: raspberry
by tonycarney » Sat Jun 09, 2012 10:29 am
rusky wrote:Log in using
user: pi
Password: raspberry
Thanks for your help
by smbjwright » Sat Jun 09, 2012 11:07 am
I tried logging in with
raspberrypi login: pi
Password: raspberry
This did not work. I am using the Debian image. The whole login looks like:
Debian GNU/Linux 6.0 raspberrypi tty1
raspberrypi login: (then I enter pi)
Password: (then I enter) raspberry
The response is:
Login incorrect
raspberrypi login:
So I am stuck.
Any ideas?
by sharpapotheosis » Sat Jun 09, 2012 12:02 pm
I had a similar problem when I started. Try typing quite a long sentence for the username, just to check whether your keyboard is working properly with the pi. On my first attempt it wasn't registering all key presses because I was trying to use quite a high powered wireless set.
Basically, if you can't type a sentence normally, try using a different (preferably normal no-frills USB) keyboard. What keyboard are you using at the minute?
by abishur » Sun Jun 10, 2012 2:42 pm
smbjwright wrote:I tried logging in with
Password: raspberry
The response is:
Login incorrect
raspberrypi login:
So I am stuck.
Any ideas?
Just to make sure, you say "the" debian image, but there have been two. What the data associated with your image?
by tonycarney » Sun Jun 10, 2012 9:08 pm
Hi thanks for your all your help i am up and running.
Tony Carney
by flyer10 » Tue Jun 19, 2012 2:01 pm
sharpapotheosis wrote:I had a similar problem when I started. Try typing quite a long sentence for the username, just to check whether your keyboard is working properly with the pi. On my first attempt it wasn't registering all key presses because I was trying to use quite a high powered wireless set.
Hi, I have the same problem and I use a normal no frills USB keyboard, (Microsoft wired desktop 600 black). I have restarted the pi quite a few times. Is there another solution?
by eckypi » Fri Jun 22, 2012 1:51 pm
I am using the version of Debian before 19-4-12, was the password different ?, I cannot login and am also using a DELL wireless keyboard and mouse, which looks as if it is typing ok by the screen.
It will not accept pi .... and raspberry as UN and PW
This is my first boot up, and HDMI will not give a picture, and AV gives overscan on screen shows as NTSC according to the TV Screen (Sharp 32in).
any ideas ..
thanks eckypi
by eckypi » Fri Jun 22, 2012 2:00 pm
I have solved the login, it was UN pi ... PW suse , as I was using the older version of Debian, overscan on AV is a problem though any ideas ?
Thanks eckypi
by AndrewS » Fri Jun 22, 2012 2:07 pm
by Mamadou Diallo » Fri Jun 22, 2012 2:25 pm
eckypi wrote:I have solved the login, it was UN pi ... PW suse , as I was using the older version of Debian, overscan on AV is a problem though any ideas ?
Thanks eckypi
I will try these options, Many Thanks, Diallo Iam.
by eckypi » Fri Jun 22, 2012 3:21 pm
Thanks Andrews for the pointers, I have now downloaded Debian 19-4-12 and this solves the overscan on AV, screen is now ok,
however I still have to solve the HDMI lack of signal, maybe your links will help ... regards eckypi
by itimpi » Fri Jun 22, 2012 5:07 pm
It is actually worth moving onto the Debian "Wheezy" beta. Despite it being labelled a beta it is a big improvement over the Debian download from 19-04.
by Eramur » Tue Jun 26, 2012 7:20 pm
From which country are you?
The keyboard settings for the raspberry pi are set for the american/british layout.
So the y and the z are changed.
So the password must be:
raspberrz
I hope that helped
