WiFi Adapter - No DHCPOFFERS received.
by AndreaRM » Fri Jan 18, 2013 3:48 pm
I have a problem with my donge WiFi (WNA1000M),
I checked and the dongle is in the list of Verified Peripherals on my Raspberry Pi Model B, the chipset is Realtek RTL8188CUS.
I connect the dongle directly into the raspberry USB.
The version of raspbian is :
root@raspberrypi:/home/pi# uname -a
Linux raspberrypi 3.2.27+ #250 PREEMPT Thu Oct 18 19:03:02 BST 2012 armv6l GNU/Linux
I have installed and configured the dongle, but i can not get an IP address from my home router, this is the error message :
root@raspberrypi:/etc# ifup wlan0
ioctl[SIOCSIWAP]: Operation not permitted
ioctl[SIOCSIWENCODEEXT]: Invalid argument
Internet Systems Consortium DHCP Client 4.2.2
Copyright 2004-2011 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/wlan0/4c:60:de:5d:38:c5
Sending on   LPF/wlan0/4c:60:de:5d:38:c5
Sending on   Socket/fallback
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 8
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 13
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 19
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 7
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6
Unable to obtain a lease on first try.  Exiting.
Failed to bring up wlan0.
This is the message after launch ifconfig :
root@raspberrypi:/etc# ifconfig -a
eth0      Link encap:Ethernet  HWaddr b8:27:eb:fa:99:dd
          inet addr:192.168.1.204  Bcast:192.168.1.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:2440 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1800 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:169498 (165.5 KiB)  TX bytes:791174 (772.6 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:3803 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3803 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:20258883 (19.3 MiB)  TX bytes:20258883 (19.3 MiB)
wlan0     Link encap:Ethernet  HWaddr 4c:60:de:5d:38:c5
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:308 errors:0 dropped:31839 overruns:0 frame:0
          TX packets:308 errors:0 dropped:5 overruns:0 carrier:0
          RX bytes:40348 (39.4 KiB)  TX bytes:47740 (46.6 KiB)
And here other info :
root@raspberrypi:/etc# lsusb
Bus 001 Device 004: ID 0846:9041 NetGear, Inc. WNA1000M 802.11bgn [Realtek RTL8188CUS]
root@raspberrypi:/etc# lsmod
Module                  Size  Used by
snd_bcm2835            12808  0
snd_pcm                74834  1 snd_bcm2835
snd_seq                52536  0
snd_timer              19698  2 snd_seq,snd_pcm
snd_seq_device          6300  1 snd_seq
snd                    52489  5 snd_seq_device,snd_timer,snd_seq,snd_pcm,snd_bcm2835
snd_page_alloc          4951  1 snd_pcm
8192cu                485042  0
root@raspberrypi:/etc# iwconfig
lo        no wireless extensions.
wlan0     IEEE 802.11bg  ESSID:"Alice-XXXXXXX"  Nickname:"<WIFI@REALTEK>"
          Mode:Managed  Frequency:2.437 GHz  Access Point: 00:1D:8B:69:5A:A0
          Bit Rate:54 Mb/s   Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Encryption key:****-****-****-****-****-****-****-****   Security mode:open
          Power Management:off
          Link Quality=100/100  Signal level=100/100  Noise level=0/100
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
eth0      no wireless extensions.
This is the configuration of WiFi.
wpa_supplicant.conf
update_config=1
network={
        ssid="Alice-XXXXX"
        psk="XXXXXXXXXXXX"
        proto=WPA
        key_mgmt=WPA-PSK
        pairwise=TKIP
        auth_alg=OPEN
/etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet dhcp
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
I can not in any way to get an ip address with wlan0, even by the graphical tool WiFi Gui made available in my distro but the problem is the same.
Do you have any idea?
Thank you very much, and sorry for my english :)
Andrea.
Raspberry Pi Model B 512MB RAM
by pjc123 » Fri Jan 18, 2013 9:14 pm
You might first want to try setting up the interfaces file without the wpa_supplicant file like the following to remove the added complication of the wpa_supplicant file:
auto lo
allow-hotplug wlan0
auto wlan0
iface wlan0 inet dhcp
wpa-ssid “YOUR SSID”
wpa-psk “YOUR KEY”
If that works, then you have an error in your wpa_supplicant file. The settings in the wpa_supplicant file have to match your router settings exactly or you will get those type of errors. Did you match the settings with your router, or just copy that file from the web somewhere? Also, if your SSID is set to hidden on your router you have to add scan_ssid=1 to the network section.
Another thing you can do is to turn up the debug mode and then look through /var/log/syslog for errors as follows:
wpa-debug-level 3
My Raspberry Pi Project Page:
http://www.flaminghellmet.com/launch/
by AndreaRM » Sat Jan 19, 2013 4:44 pm
thanks for your reply pjc123 :)
I have added the line wpa-ssid and wpa-psk and remove te wpa_supplicanta conf file, but the result is the same, this not works :(
The wpa_supplicant file match with my router settings, and my SSID is not set to hidden.
I have set the "wpa-debug-level 3" with the wpa-roam, but i didn't understand the reason of error.
this is the syslog output
Jan 19 17:31:45 raspberrypi rsyslogd-2177: imuxsock lost 116 messages from pid 2820 due to rate-limiting
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: wlan0: RX EAPOL from 00:1d:8b:69:5a:a0
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: RX EAPOL - hexdump(len=99): 01 03 00 5f fe 00 89 00 20 00 00 00 00 00 00 00 03 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: wlan0: IEEE 802.1X RX: version=1 type=3 length=95
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: wlan0:   EAPOL-Key type=254
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: wlan0:   key_info 0x89 (ver=1 keyidx=0 rsvd=0 Pairwise Ack)
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: wlan0:   key_length=32 key_data_length=0
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]:   replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 03
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]:   key_nonce - hexdump(len=32): 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]:   key_iv - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]:   key_rsc - hexdump(len=8): 00 00 00 00 00 00 00 00
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]:   key_id (reserved) - hexdump(len=8): 00 00 00 00 00 00 00 00
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]:   key_mic - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: WPA: RX EAPOL-Key - hexdump(len=99): 01 03 00 5f fe 00 89 00 20 00 00 00 00 00 00 00 03 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: wlan0: State: 4WAY_HANDSHAKE -> 4WAY_HANDSHAKE
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: wlan0: WPA: RX message 1 of 4-Way Handshake from 00:1d:8b:69:5a:a0 (ver=1)
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: WPA: PTK derivation - A1=4c:60:de:5d:38:c5 A2=00:1d:8b:69:5a:a0
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: WPA: Nonce1 - hexdump(len=32): 49 e9 37 53 49 35 10 7b 1c e7 a4 d7 79 c9 87 8b 11 d9 f3 de 32 be ba 74 0e 93 12 6c 06 6e af 42
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: WPA: Nonce2 - hexdump(len=32): 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: WPA: PMK - hexdump(len=32): [REMOVED]
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: WPA: PTK - hexdump(len=64): [REMOVED]
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: WPA: WPA IE for msg 2/4 - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: WPA: Replay Counter - hexdump(len=8): 00 00 00 00 00 00 00 03
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: wlan0: WPA: Sending EAPOL-Key 2/4
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: WPA: KCK - hexdump(len=16): [REMOVED]
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: WPA: Derived Key MIC - hexdump(len=16): 0e 24 2f 8f c8 ae 35 7a 84 61 9b 4d a4 70 e9 5d
Jan 19 17:31:45 raspberrypi wpa_supplicant[2820]: WPA: TX EAPOL-Key - hexdump(len=123): 01 03 00 77 fe 01 09 00 20 00 00 00 00 00 00 00 03 49 e9 37 53 49 35 10 7b 1c e7 a4 d7 79 c9 87 8b 11 d9 f3 de 32 be ba 74 0e 93 12 6c 06 6e af 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0e 24 2f 8f c8 ae 35 7a 84 61 9b 4d a4 70 e9 5d 00 18 dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: wlan0: RX EAPOL from 00:1d:8b:69:5a:a0
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: RX EAPOL - hexdump(len=99): 01 03 00 5f fe 00 89 00 20 00 00 00 00 00 00 00 04 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: wlan0: IEEE 802.1X RX: version=1 type=3 length=95
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: wlan0:   EAPOL-Key type=254
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: wlan0:   key_info 0x89 (ver=1 keyidx=0 rsvd=0 Pairwise Ack)
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: wlan0:   key_length=32 key_data_length=0
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]:   replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 04
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]:   key_nonce - hexdump(len=32): 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]:   key_iv - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]:   key_rsc - hexdump(len=8): 00 00 00 00 00 00 00 00
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]:   key_id (reserved) - hexdump(len=8): 00 00 00 00 00 00 00 00
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]:   key_mic - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: WPA: RX EAPOL-Key - hexdump(len=99): 01 03 00 5f fe 00 89 00 20 00 00 00 00 00 00 00 04 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: wlan0: State: 4WAY_HANDSHAKE -> 4WAY_HANDSHAKE
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: wlan0: WPA: RX message 1 of 4-Way Handshake from 00:1d:8b:69:5a:a0 (ver=1)
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: WPA: PTK derivation - A1=4c:60:de:5d:38:c5 A2=00:1d:8b:69:5a:a0
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: WPA: Nonce1 - hexdump(len=32): 49 e9 37 53 49 35 10 7b 1c e7 a4 d7 79 c9 87 8b 11 d9 f3 de 32 be ba 74 0e 93 12 6c 06 6e af 42
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: WPA: Nonce2 - hexdump(len=32): 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: WPA: PMK - hexdump(len=32): [REMOVED]
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: WPA: PTK - hexdump(len=64): [REMOVED]
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: WPA: WPA IE for msg 2/4 - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: WPA: Replay Counter - hexdump(len=8): 00 00 00 00 00 00 00 04
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: wlan0: WPA: Sending EAPOL-Key 2/4
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: WPA: KCK - hexdump(len=16): [REMOVED]
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: WPA: Derived Key MIC - hexdump(len=16): 34 ba ff 93 8b 6f fe 1b 39 56 a4 04 f5 41 eb db
Jan 19 17:31:46 raspberrypi wpa_supplicant[2820]: WPA: TX EAPOL-Key - hexdump(len=123): 01 03 00 77 fe 01 09 00 20 00 00 00 00 00 00 00 04 49 e9 37 53 49 35 10 7b 1c e7 a4 d7 79 c9 87 8b 11 d9 f3 de 32 be ba 74 0e 93 12 6c 06 6e af 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 34 ba ff 93 8b 6f fe 1b 39 56 a4 04 f5 41 eb db 00 18 dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: wlan0: RX EAPOL from 00:1d:8b:69:5a:a0
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: RX EAPOL - hexdump(len=99): 01 03 00 5f fe 00 89 00 20 00 00 00 00 00 00 00 05 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: wlan0: IEEE 802.1X RX: version=1 type=3 length=95
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: wlan0:   EAPOL-Key type=254
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: wlan0:   key_info 0x89 (ver=1 keyidx=0 rsvd=0 Pairwise Ack)
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: wlan0:   key_length=32 key_data_length=0
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]:   replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 05
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]:   key_nonce - hexdump(len=32): 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]:   key_iv - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]:   key_rsc - hexdump(len=8): 00 00 00 00 00 00 00 00
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]:   key_id (reserved) - hexdump(len=8): 00 00 00 00 00 00 00 00
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]:   key_mic - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: WPA: RX EAPOL-Key - hexdump(len=99): 01 03 00 5f fe 00 89 00 20 00 00 00 00 00 00 00 05 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: wlan0: State: 4WAY_HANDSHAKE -> 4WAY_HANDSHAKE
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: wlan0: WPA: RX message 1 of 4-Way Handshake from 00:1d:8b:69:5a:a0 (ver=1)
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: WPA: PTK derivation - A1=4c:60:de:5d:38:c5 A2=00:1d:8b:69:5a:a0
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: WPA: Nonce1 - hexdump(len=32): 49 e9 37 53 49 35 10 7b 1c e7 a4 d7 79 c9 87 8b 11 d9 f3 de 32 be ba 74 0e 93 12 6c 06 6e af 42
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: WPA: Nonce2 - hexdump(len=32): 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: WPA: PMK - hexdump(len=32): [REMOVED]
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: WPA: PTK - hexdump(len=64): [REMOVED]
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: WPA: WPA IE for msg 2/4 - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: WPA: Replay Counter - hexdump(len=8): 00 00 00 00 00 00 00 05
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: wlan0: WPA: Sending EAPOL-Key 2/4
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: WPA: KCK - hexdump(len=16): [REMOVED]
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: WPA: Derived Key MIC - hexdump(len=16): e4 c1 29 d8 fd 9e bc f7 a3 c5 35 23 50 6a 74 f0
Jan 19 17:31:47 raspberrypi wpa_supplicant[2820]: WPA: TX EAPOL-Key - hexdump(len=123): 01 03 00 77 fe 01 09 00 20 00 00 00 00 00 00 00 05 49 e9 37 53 49 35 10 7b 1c e7 a4 d7 79 c9 87 8b 11 d9 f3 de 32 be ba 74 0e 93 12 6c 06 6e af 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 e4 c1 29 d8 fd 9e bc f7 a3 c5 35 23 50 6a 74 f0 00 18 dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: wlan0: RX EAPOL from 00:1d:8b:69:5a:a0
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: RX EAPOL - hexdump(len=99): 01 03 00 5f fe 00 89 00 20 00 00 00 00 00 00 00 06 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: wlan0: IEEE 802.1X RX: version=1 type=3 length=95
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: wlan0:   EAPOL-Key type=254
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: wlan0:   key_info 0x89 (ver=1 keyidx=0 rsvd=0 Pairwise Ack)
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: wlan0:   key_length=32 key_data_length=0
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]:   replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 06
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]:   key_nonce - hexdump(len=32): 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]:   key_iv - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]:   key_rsc - hexdump(len=8): 00 00 00 00 00 00 00 00
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]:   key_id (reserved) - hexdump(len=8): 00 00 00 00 00 00 00 00
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]:   key_mic - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: WPA: RX EAPOL-Key - hexdump(len=99): 01 03 00 5f fe 00 89 00 20 00 00 00 00 00 00 00 06 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: wlan0: State: 4WAY_HANDSHAKE -> 4WAY_HANDSHAKE
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: wlan0: WPA: RX message 1 of 4-Way Handshake from 00:1d:8b:69:5a:a0 (ver=1)
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: WPA: PTK derivation - A1=4c:60:de:5d:38:c5 A2=00:1d:8b:69:5a:a0
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: WPA: Nonce1 - hexdump(len=32): 49 e9 37 53 49 35 10 7b 1c e7 a4 d7 79 c9 87 8b 11 d9 f3 de 32 be ba 74 0e 93 12 6c 06 6e af 42
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: WPA: Nonce2 - hexdump(len=32): 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: WPA: PMK - hexdump(len=32): [REMOVED]
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: WPA: PTK - hexdump(len=64): [REMOVED]
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: WPA: WPA IE for msg 2/4 - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: WPA: Replay Counter - hexdump(len=8): 00 00 00 00 00 00 00 06
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: wlan0: WPA: Sending EAPOL-Key 2/4
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: WPA: KCK - hexdump(len=16): [REMOVED]
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: WPA: Derived Key MIC - hexdump(len=16): 99 ca 89 a6 3e 7b 3e d7 0a 26 b9 6f 2a ce bb ac
Jan 19 17:31:48 raspberrypi wpa_supplicant[2820]: WPA: TX EAPOL-Key - hexdump(len=123): 01 03 00 77 fe 01 09 00 20 00 00 00 00 00 00 00 06 49 e9 37 53 49 35 10 7b 1c e7 a4 d7 79 c9 87 8b 11 d9 f3 de 32 be ba 74 0e 93 12 6c 06 6e af 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 99 ca 89 a6 3e 7b 3e d7 0a 26 b9 6f 2a ce bb ac 00 18 dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: wlan0: RX EAPOL from 00:1d:8b:69:5a:a0
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: RX EAPOL - hexdump(len=99): 01 03 00 5f fe 00 89 00 20 00 00 00 00 00 00 00 07 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: wlan0: IEEE 802.1X RX: version=1 type=3 length=95
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: wlan0:   EAPOL-Key type=254
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: wlan0:   key_info 0x89 (ver=1 keyidx=0 rsvd=0 Pairwise Ack)
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: wlan0:   key_length=32 key_data_length=0
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]:   replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 07
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]:   key_nonce - hexdump(len=32): 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]:   key_iv - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]:   key_rsc - hexdump(len=8): 00 00 00 00 00 00 00 00
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]:   key_id (reserved) - hexdump(len=8): 00 00 00 00 00 00 00 00
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]:   key_mic - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: WPA: RX EAPOL-Key - hexdump(len=99): 01 03 00 5f fe 00 89 00 20 00 00 00 00 00 00 00 07 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: wlan0: State: 4WAY_HANDSHAKE -> 4WAY_HANDSHAKE
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: wlan0: WPA: RX message 1 of 4-Way Handshake from 00:1d:8b:69:5a:a0 (ver=1)
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: WPA: PTK derivation - A1=4c:60:de:5d:38:c5 A2=00:1d:8b:69:5a:a0
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: WPA: Nonce1 - hexdump(len=32): 49 e9 37 53 49 35 10 7b 1c e7 a4 d7 79 c9 87 8b 11 d9 f3 de 32 be ba 74 0e 93 12 6c 06 6e af 42
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: WPA: Nonce2 - hexdump(len=32): 51 4c 8f 87 ab 41 15 1d 68 84 17 10 9a 1f 74 50 27 f2 53 7f a9 a8 0f 59 8f 9d c1 18 5c 22 d9 88
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: WPA: PMK - hexdump(len=32): [REMOVED]
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: WPA: PTK - hexdump(len=64): [REMOVED]
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: WPA: WPA IE for msg 2/4 - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: WPA: Replay Counter - hexdump(len=8): 00 00 00 00 00 00 00 07
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: wlan0: WPA: Sending EAPOL-Key 2/4
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: WPA: KCK - hexdump(len=16): [REMOVED]
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: WPA: Derived Key MIC - hexdump(len=16): a7 59 2a 52 76 12 e9 80 d4 6a 47 53 01 3d e4 fd
Jan 19 17:31:49 raspberrypi wpa_supplicant[2820]: WPA: TX EAPOL-Key - hexdump(len=123): 01 03 00 77 fe 01 09 00 20 00 00 00 00 00 00 00 07 49 e9 37 53 49 35 10 7b 1c e7 a4 d7 79 c9 87 8b 11 d9 f3 de 32 be ba 74 0e 93 12 6c 06 6e af 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 a7 59 2a 52 76 12 e9 80 d4 6a 47 53 01 3d e4 fd 00 18 dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wlan0: Authentication with 00:1d:8b:69:5a:a0 timed out.
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: CTRL_IFACE monitor send - hexdump(len=21): 2f 74 6d 70 2f 77 70 61 5f 63 74 72 6c 5f 32 38 37 35 2d 31 00
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: Added BSSID 00:1d:8b:69:5a:a0 into blacklist
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wpa_driver_wext_disassociate
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: WEXT: Failed to clear BSSID selection on disconnect
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wlan0: No keys have been configured - skip key clearing
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wlan0: State: 4WAY_HANDSHAKE -> DISCONNECTED
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wpa_driver_wext_set_operstate: operstate 0->0 (DORMANT)
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: netlink: Operstate: linkmode=-1, operstate=5
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: EAPOL: External notification - portEnabled=0
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: EAPOL: SUPP_PAE entering state DISCONNECTED
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: EAPOL: Supplicant port status: Unauthorized
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: EAPOL: SUPP_BE entering state INITIALIZE
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: EAPOL: External notification - portValid=0
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: EAPOL: External notification - EAP success=0
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wlan0: Setting scan request: 1 sec 0 usec
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: RTM_NEWLINK: operstate=0 ifi_flags=0x11003 ([UP][LOWER_UP])
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: RTM_NEWLINK, IFLA_IFNAME: Interface 'wlan0' added
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: WEXT: if_removed already cleared - ignore event
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: Wireless event: cmd=0x8b15 len=20
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: Wireless event: new AP: 00:00:00:00:00:00
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wlan0: Event DISASSOC (1) received
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wlan0: Disassociation notification
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wlan0: WPA: Auto connect enabled: try to reconnect (wps=0)
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: Added BSSID 00:00:00:00:00:00 into blacklist
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wlan0: Setting scan request: 0 sec 100000 usec
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wlan0: CTRL-EVENT-DISCONNECTED bssid=00:00:00:00:00:00 reason=0
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wlan0: Disconnect event - remove keys
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wpa_driver_wext_set_key: alg=0 key_idx=0 set_tx=0 seq_len=0 key_len=0
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wpa_driver_wext_set_key: alg=0 key_idx=1 set_tx=0 seq_len=0 key_len=0
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wpa_driver_wext_set_key: alg=0 key_idx=2 set_tx=0 seq_len=0 key_len=0
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wpa_driver_wext_set_key: alg=0 key_idx=3 set_tx=0 seq_len=0 key_len=0
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wpa_driver_wext_set_key: alg=0 key_idx=4 set_tx=0 seq_len=0 key_len=0
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: Driver did not support SIOCSIWENCODEEXT
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wpa_driver_wext_set_key: alg=0 key_idx=5 set_tx=0 seq_len=0 key_len=0
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wlan0: State: DISCONNECTED -> DISCONNECTED
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: RTM_NEWLINK: operstate=0 ifi_flags=0x1003 ([UP])
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: Wireless event: cmd=0x8b1a len=40
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wlan0: State: DISCONNECTED -> SCANNING
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wlan0: Starting AP scan for wildcard SSID
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: Scan requested (ret=0) - scan timeout 30 seconds
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: Wireless event: cmd=0x8b19 len=8
Jan 19 17:31:52 raspberrypi wpa_supplicant[2820]: wlan0: Event SCAN_RESULTS (3) received
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: Received 317 bytes of scan results (1 BSSes)
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: Sorted scan results
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: 00:1d:8b:69:5a:a0 freq=2437 qual=100 noise=0 level=87 flags=0x2
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: BSS: Start scan result update 3
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: Add randomness: count=4 entropy=0
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: random pool - hexdump(len=128): [REMOVED]
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: random_mix_pool - hexdump(len=8): [REMOVED]
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: random_mix_pool - hexdump(len=5): [REMOVED]
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: New scan results available
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: CTRL_IFACE monitor send - hexdump(len=21): 2f 74 6d 70 2f 77 70 61 5f 63 74 72 6c 5f 32 38 37 35 2d 31 00
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: WPS: attr type=0x104a len=1
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: WPS: attr type=0x1044 len=1
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: WPS: attr type=0x1041 len=1
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: WPS: attr type=0x103b len=1
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: WPS: attr type=0x1047 len=16
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: WPS: attr type=0x1021 len=0
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: WPS: attr type=0x1023 len=0
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: WPS: attr type=0x1024 len=0
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: WPS: attr type=0x1042 len=0
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: WPS: attr type=0x1054 len=8
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: WPS: attr type=0x1011 len=14
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: WPS: attr type=0x1008 len=2
Jan 19 17:31:54 raspberrypi ifplugd(wlan0)[1428]: Link beat lost.
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: Selecting BSS from priority group 0
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: 0: 00:1d:8b:69:5a:a0 ssid='Alice-18138544' wpa_ie_len=24 rsn_ie_len=0 caps=0x11 level=87 wps
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0:    skip - blacklisted (count=1 limit=0)
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: No APs found - clear blacklist and try again
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: Removed BSSID 00:00:00:00:00:00 from blacklist (clear)
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: Removed BSSID 00:1d:8b:69:5a:a0 from blacklist (clear)
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0:    selected based on WPA IE
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0:    selected BSS 00:1d:8b:69:5a:a0 ssid='Alice-18138544'
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: Request association: reassociate: 1  selected: 00:1d:8b:69:5a:a0  bssid: 00:00:00:00:00:00  pending: 00:00:00:00:00:00  wpa_state: SCANNING
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: Trying to associate with 00:1d:8b:69:5a:a0 (SSID='Alice-18138544' freq=2437 MHz)
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: FT: Stored MDIE and FTIE from (Re)Association Response - hexdump(len=0):
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: Cancelling scan request
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: WPA: clearing own WPA/RSN IE
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: Automatic auth_alg selection: 0x1
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: Overriding auth_alg selection: 0x1
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: WPA: using IEEE 802.11i/D3.0
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: WPA: Selected cipher suites: group 8 pairwise 8 key_mgmt 2 proto 1
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: WPA: set AP WPA IE - hexdump(len=26): dd 18 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02 00 00
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: WPA: clearing AP RSN IE
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: WPA: using GTK TKIP
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: WPA: using PTK TKIP
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: WPA: using KEY_MGMT WPA-PSK
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: WPA: not using MGMT group cipher
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: WPA: Set own WPA IE default - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: No keys have been configured - skip key clearing
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: State: SCANNING -> ASSOCIATING
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wpa_driver_wext_set_operstate: operstate 0->0 (DORMANT)
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: netlink: Operstate: linkmode=-1, operstate=5
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wpa_driver_wext_associate
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wpa_driver_wext_set_drop_unencrypted
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wpa_driver_wext_set_psk
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: Association request to the driver failed
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: Setting authentication timeout: 5 sec 0 usec
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: EAPOL: External notification - EAP success=0
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: EAPOL: Supplicant port status: Unauthorized
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: EAPOL: External notification - EAP fail=0
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: EAPOL: External notification - portControl=Auto
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: RTM_NEWLINK: operstate=0 ifi_flags=0x1003 ([UP])
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: RTM_NEWLINK, IFLA_IFNAME: Interface 'wlan0' added
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: WEXT: if_removed already cleared - ignore event
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: Wireless event: cmd=0x8b19 len=8
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: Event SCAN_RESULTS (3) received
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: wlan0: BSS: Start scan result update 4
Jan 19 17:31:54 raspberrypi wpa_supplicant[2820]: Add randomness: count=5 entropy=1
Jan 19 17:31:54 raspberrypi rsyslogd-2177: imuxsock begins to drop messages from pid 2820 due to rate-limiting
Jan 19 17:31:55 raspberrypi ifplugd(wlan0)[1428]: Link beat detected.
Jan 19 17:31:58 raspberrypi rsyslogd-2177: imuxsock lost 190 messages from pid 2820 due to rate-limiting
This lines repeated many times...
I do not know how to solve
thanks
by kumar303 » Sun Feb 24, 2013 6:26 am
Thank you pjc123 ! I ran into this same thing but when I commented out my wpa_supplicant.conf and entered wpa-ssid and wpa-psk manually it finally started working.
I really can't spot what's wrong with my wpa_supplicant.conf file. My password has spaces in it so I am suspicious of that.
For the record, I also was unable to get my wifi working with an inet manual configuration.
by pjc123 » Sun Feb 24, 2013 1:25 pm
kumar303 wrote:Thank you pjc123 ! I ran into this same thing but when I commented out my wpa_supplicant.conf and entered wpa-ssid and wpa-psk manually it finally started working.
Great. Do yourself a favor and make a backup copy of your working configuration file, especially if you are going to play around with settings later on. The wpa_supplicant file can be a real bear to get working, but once you do, it has a lot of useful options. Certainly if your password works in the /etc/network file I suspect that it will work in the wpa_supplicant file (in fact the wpa_supplicant file is more forgiving with password characters as I found out), so you now know it is something else. If you post what both of your network files looked like when you were attempting to use wpa_supplicant I might be able to detect a basic command or syntax error. I just would not know what your access point requires and if those settings are wrong. I use the inet manual method and it works very good. Or maybe that you have it working you just don't care; I can see that!
by pioap » Sun Feb 24, 2013 8:13 pm
I'm new to linux and the pi and I want to configure a wifi device as part of a project to arrange a caravan based wifi hot spot. I need to connect to a distant wifi hotspot for my internet connection so I am using a CPE solutions high gain pole mountable usb "dongle".
I am having the same problem with the CPE Solutions USB "dongle".
Inside the box it has a RT2571 chip and lsusb returns:
Bus 001 Device 009: ID 148f:2573 Railink Technology, copr. RT2501/RT2573 Wireless adapter
I'm using a D Link powered USB hub.
I have installed railink firmware, wireless-tools and, in despiration wicd.
lksmod lists (among other things):
Module rt73usb
rt2x00usb
rt2x00lib
/etc/network/interfaces contains:
auto wlan0
wpa-conf /etc/wpa.config
/etc/wpa.configcontains
network={
ssid=”YOUR_SSID”
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP TKIP
group=CCMP TKIP
psk=”WPA-PASSWORD”
on network restart I get a warning Running /etc/init.d/networking restart is depricated because it may not reenable some interfaces....
Is this why I get "No DHCPOFFERS" or shoud I be looking elsewhere? Any help much apprciated.
by gers_gen » Sun Aug 25, 2013 5:41 pm
Hello Andrea
did you resolve this problem?
I have the same issue: interestingly I have a similar wlan chip (RTL8188SU).
I have tried all suggestions that I found so far: but the rpi does not receive any dhcp offers. Althought the device seems to be working fine!
by cray » Sun Sep 22, 2013 1:58 am
I had the same issue while using an external USB hub with power. I found a hint in the Raspberry Pi User Guide by Upton on pg 70. "Some adapter models are known to cause problems with certain keyboards." In my case I have a realtek adapter and an HP usb keyboard. I keyed in sudo ifup wlan0, then I quickly unplugged my keyboard and everything connected fine. I plugged back in my keyboard and things are still up. I'll be using ssh so I can dump the keyboard but I'll pick up another just to have a back-up.
