Internet connection via Wifi
by JonaHex » Mon Jan 07, 2013 9:29 am
Hi All,
I recently started playing with the Raspberry Pi, I started up and all is well but I don’t have access to a Ethernet connection at the time. I bought the Edimax wlan dongle and want to connect to a mobile hotspot / or a friends wifi router. The problem I have is the edimax is configured and connected as I can see when on the status and on ifconfig but I still don’t have internet access.
Any ideas on what it could be/
by Mobius » Tue Jan 08, 2013 1:48 am
Try sudo iwconfig and see if you have the correct SSID and password. It should also show a MAC address next to "Access Point". If it says "Not Associated" then you don't have a connection.
by mango » Tue Jan 08, 2013 4:34 am
So how does one connect to it then? I am trying to connect to my wifi which was WPA2 security passkey, I can find the network, but not sure how to connect, enter my passkey etc...?
Cheers
by Forris » Tue Jan 08, 2013 6:50 am
If you have used the 'startx' command and are talking to your Pi using the GUI (the page with the big raspberry in the middle and a few icons around), there should be an icon on the screen call 'WiFi Setup'.Use this as the easiest method to setup your connection.
by mango » Tue Jan 08, 2013 7:48 am
Nah I'm talking about command line, not via startx.
I can only have my keyboard and wifi dongle plugged in at once, no mouse, so no point trying to use the GUI anyway. I have a USB hub but not powered, so it can only run one thing off it, so it's still 2 USB slots effectively, so looking for a CLI solution to connecting to WPA2 Wifi, have tried using wpa_suppllicant, but not sure where or if it saves the file when I do wpa_passphrase XXX XXX.
by Jim JKla » Tue Jan 08, 2013 7:59 am
You only have to use startx once to set up the connection once you have the connection the RPi connects.
Case study here.
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=26&t=28339
by Chapindad » Tue Jan 08, 2013 9:58 pm
Sounds like a routing issue.
Post your: /etc/network/interfaces
by Mobius » Wed Jan 09, 2013 12:40 am
Yup. /etc/network/interfaces is where you manually set up your ethernet and wireless devices.
by Lonewolff » Wed Jan 09, 2013 3:33 am
This is how I got my WIFI up and running via the command line.
Type sudo nano /etc/network/interfaces
Add these lines
auto wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
Save and exit
Type sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
add the following
network={
ssid="your_ssid_here"
psk="your_password_here"
Save and exit, then sudo reboot
Loving my peice of the Pi
by JonaHex » Wed Jan 09, 2013 8:17 am
Thank you to all to comments.
I can detect the network but it seems not to be connecting.
Event list in the WIFI setup app says = associated request to driver failed?
Any ideas on what I can do to get this working
