How to shutdown the Raspberry Pi?
by atzensepp » Wed Oct 03, 2012 8:17 pm
I want to use my Pi as internet radio with mpd. It should work as a stand alone device. Start up is no problem since mpd is strting automatically. But when I want to turn it off Iam currently pulling the power plug. Since it is a linux device I am afraid that by this rough procedure one time the file system could get corrupted. What would be your advice to do a decent shutdown or is the power off method not so critical for the pi?
by rymate1234 » Wed Oct 03, 2012 8:25 pm
Just run sudo halt from a console to shut your pi down. This initiates the linux shutdown routine.
by alexeames » Wed Oct 03, 2012 8:26 pm
Best thing to do is enable ssh (it should be enabled if you haven't disabled it) then ssh into it from another computer (or even your smartphone) and type
sudo halt
Further info here...
http://raspi.tv/2012/how-to-safely-shutdown-or-reboot-your-raspberry-pi
Alex Eames RasPi.TV HDMIPi.com RasP.iO
by ski522 » Wed Oct 03, 2012 11:46 pm
Leave it running, why do you need to shut it down? The power the device uses is minimal.
by RockMachine » Thu Oct 04, 2012 5:06 pm
Sudo poweroff
by mckorr » Fri Oct 05, 2012 5:05 pm
ski522 wrote:Leave it running, why do you need to shut it down? The power the device uses is minimal.
In order to move it to a different location, or to swap out the SD card, or.... Lots of reasons you might have to shut it down.
by atzensepp » Tue Oct 09, 2012 8:14 pm
rymate1234 wrote:Just run sudo halt from a console to shut your pi down. This initiates the linux shutdown routine.
Sure this is the correct way if one has a terminal connection.
But I am interested in a way to safely power off the Pi with a simple button press without the need for logging in just for the purpose of powering down.
Following ideas I had so far:
  • write a demon that is permanently checking one of the GPIO pins and shutting down the Pi when a special button is pressed
  • write a PHP script to power it down via web with an Iphone as controller ( :? )
  • build a little UPS device that detects a power off, supplies the Pi for some seconds until it powers off after sending a shutdown-signal via GPIO to the Pi. (a demon needed too)
I was hoping this problem has been solved already. More elegant suggestions are welcome.
by toxibunny » Tue Oct 09, 2012 8:26 pm
I use either sudo shutdown, then pull the plug, or sudo shutdown -r to reset.
What's all this 'sudo halt' and 'sudo poweroff' stuff?
note: I may or may not know what I'm talking about...
by toxibunny » Tue Oct 09, 2012 8:27 pm
yeah, I also mostly just leave it running, too... which I feel a bit dodgy about, to be honest.
by mahjongg » Tue Oct 09, 2012 8:29 pm
These are shortcuts for the more difficult to remember command
sudu shutdown -h now
why shouldn't you make something easy that you have to do so often.
by mak3r » Tue Oct 09, 2012 9:09 pm
atzensepp wrote:[*] build a little UPS device that detects a power off, supplies the Pi for some seconds until it powers off after sending a shutdown-signal via GPIO to the Pi. (a demon needed too)[/list]
You probably don't need an entire ups. Why not just a switch that signals one of the inputs.
by atzensepp » Wed Oct 10, 2012 9:02 pm
Yes an ups would be overkill. Probably something like that is sufficient:
http://picnote.blogspot.de/2008/10/batt ... oller.html
(The battery could be used for a RTC (e.g. DS1337) too.)
B.t.w. I found a thread in this forum that deals with that problem: "Safe hard power-off"
viewtopic.php?f=29&t=17140
by atzensepp » Thu Oct 11, 2012 9:06 pm
What about using a large (Gold Cap) capacitor as back-up power supply to enable a decent shutdown?
The Pi is consuming 2 W at 5 V. For a 30s Shutdown cycle a charge of 12 As is needed which could be provided by a capacitor with 2.4 F capacity.
Do you think that would work?
by FruityPenguin » Sun Nov 11, 2012 4:01 pm
I was also thinking about using a Gold Cap for a mini-UPS, as I see several advantages:
  • Doesn't require a complex charging circuit
  • It can easily supply more than enough power for a quick shutdown
  • Has a longer shelf life (up to 10 years) than rechargeable batteries
  • Small
Detecting that mains power has failed and triggering a GPIO pin to initiate the shutdown should also be easy to do.
Unfortunately my skills in electronics are too basic to actually turn this idea into a working circuit. :oops:
