Boot Errors
by geffers » Fri Jul 06, 2012 9:09 pm
I need to try and narrow down if this is a board problem or some other setup problem.
On boot I get a continuous error;
mmc0: Error 110 whilst initialising SD card and Problem reading SD status register.
After a period of time, up to 5 minutes it boots.
HDPARM -t shows 1.16MB/sec which is ridiculously slow (10.43MB/sec) on my HP laptop.
A Sandisk Extreme Class 10 will not boot at all continuously giving error;
mmc0: timeout waiting for hardware interrupt.
Using a 1AMP PSU.
Geffers
by alexeames » Fri Jul 06, 2012 9:13 pm
Sounds like an SD card issue to me. Are you using the debian wheezy beta? It works with a wider selection of SD cards than the Squeeze version.
Alex Eames RasPi.TV HDMIPi.com RasP.iO
by mahjongg » Fri Jul 06, 2012 9:15 pm
Read the wiki first, all your topics are discussed there, and in other forumtopics, like this one:
http://www.raspberrypi.org/phpBB3/viewtopic.php?p=113423#p113423
by geffers » Sat Jul 07, 2012 11:50 am
mahjongg wrote:Read the wiki first, all your topics are discussed there, and in other forumtopics, like this one:
Thanks Mahjongg, that sorted my unbranded (Supposedly Toshiba) SD card but strangely not my Sandisk Extreme.
Tried Wheezy on the Sandisk but I get nothing after the Raspberry image comes up on the screen.
Geffers
by mahjongg » Sat Jul 07, 2012 2:24 pm
Perhaps the "SanDisk extreme" is a cheap chinese copy, a "fake". Its especially the SanDisk Extreme brand that is copied, and a large part of SanDisk Extremes you buy on ebay are fakes!
Just google for "SanDisk fake" and you will see what I mean.
The biggest problem (except very low quality and speed) is that "2 GB" fake cards often actually are only capable of storing 1 GB.
by geffers » Sat Jul 07, 2012 10:48 pm
mahjongg wrote:Perhaps the "SanDisk extreme" is a cheap chinese copy, a "fake". Its especially the SanDisk Extreme brand that is copied, and a large part of SanDisk Extremes you buy on ebay are fakes!
I think I am OK with the sandisk, bought from a reputable outlet (Not ebay) and it shows as 16GB.
Geffers
by mahjongg » Sun Jul 08, 2012 3:10 pm
There is a recent discovered issue with pullups not enabled on some of the SD-card control and data lines, which can be solved in software, but might not yet have been in the software you have been using.
by dom » Sun Jul 08, 2012 3:47 pm
mahjongg wrote:There is a recent discovered issue with pullups not enabled on some of the SD-card control and data lines, which can be solved in software, but might not yet have been in the software you have been using.
Yes download bootcode.bin from here:
https://github.com/raspberrypi/firmware ... aster/boot
and replace the one on your sdcard.
by geffers » Tue Jul 10, 2012 8:28 pm
OK, done that, will check it out tomorrow.
Thanks,
Geffers
by geffers » Wed Jul 11, 2012 7:45 pm
regretfully that didn't work, same error message :(
Geffers
