Share RPi Folder
by gjs » Sun Jun 10, 2012 12:10 pm
How can I share an RPi folder on a windows network? So that I can write a file on a windows machine directly to the RPi folder.
Thanks.
by parkenator » Sun Jun 10, 2012 3:01 pm
Some one with more knowledge than me is sure to come along and correct me on this, but what about SAMBA. Or ftp. May be worth having a look?
by bredman » Sun Jun 10, 2012 5:19 pm
See this page for guide on how to set up Samba
http://elinux.org/R-Pi_NAS
by stevep » Sun Jun 10, 2012 6:48 pm
Asked the same thing the other day - Bredman gave me that reply and it was spot on - I was able to share files both ways and it was a very painless procedure, with one small exception - there is a bit of a syntax error in the guide which I highlighted in this post:
viewtopic.php?f=26&t=7845
I also edited the Wiki to add a note to that effect - I'm no expert so I may well be wrong, so hopefully someone else will check my note for accuracy.
by gjs » Sun Jun 10, 2012 7:49 pm
Thank you. That worked fine. I don't know about the chmod edit as I didn't do that step.
by bredman » Sun Jun 10, 2012 8:46 pm
The two different versions of the chmod command have the same result.
I will change it to your version, except for the fact that o=rx-w would be better written as o=rx.
