cpu usage
by jcrowson12 » Mon Nov 05, 2012 11:48 pm
My RPi's cpu is constantly maxed out. The python games that come with it use more than 90% of the cpu, but only uses ~44mb of the 512mb. Is that normal?
Thanks for all of your support.
by abishur » Tue Nov 06, 2012 2:15 am
Many questions come to mind, namely are you trying to run these programs from within X or from the bash prompt? Which Disto are you using? what's your current memory split? :-)
Dear forum: Play nice ;-)
by jcrowson12 » Tue Nov 06, 2012 3:18 am
I'm not using bash. Not sure about X. Raspbian. 384 and 128.
by abishur » Tue Nov 06, 2012 4:31 am
X is the thing you enter when you type "startx" (The desktop environment), bash is just the command prompt
by jcrowson12 » Tue Nov 06, 2012 12:16 pm
Well I am using the GUI x.
by redhawk » Tue Nov 06, 2012 12:35 pm
There's no hardware acceleration for your X display therefore any moving images would cause the CPU usage to rise.
Richard S.
by jcrowson12 » Tue Nov 06, 2012 12:43 pm
Would another OS be faster?
by redhawk » Tue Nov 06, 2012 12:52 pm
You could try Xming it's an X-Windows client for Windows I use it to access my PI desktop on my desktop since I don't have HDMI. - viewtopic.php?f=26&t=18420
In theory it should help to off-load some of the processing power to Windows which would be handling the images and not the PI.
Richard S.
by pluggy » Tue Nov 06, 2012 1:15 pm
It doesn't take much to max out the CPU, truth of the matter is the Pi has a puny CPU. It has an impressive GPU, which is what invariably gets demoed when they are showing it off, but most stuff doesn't use the GPU.
Running a remote X server like redhawk says helps, since it takes a lot of the weight off the Pi.
I must not tread on too many sacred cows......
