WiFi dongle that works without the USB hub
by tomexx » Mon Nov 05, 2012 4:01 pm
I'm trying to make the Pi more portable (ie replace ethernet with wifi and eventually run it off batteries).
I have seen the list of approved devices here: http://elinux.org/RPi_VerifiedPeripherals
Can you recommend a wifi dongle that works well when powered directly from the Pi without the need of a powered USB hub?
Thanks,
Tom
by malakai » Mon Nov 05, 2012 4:11 pm
An entire thread http://www.raspberrypi.org/phpBB3/viewtopic.php?f=46&t=11309&hilit=wireless+powered pretty much for me the edimax on ebay can be bought for about $6 in the US.
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
by tomexx » Mon Nov 05, 2012 4:14 pm
Thanks malakai, I'll look into it.
by malakai » Mon Nov 05, 2012 4:34 pm
by pluggy » Mon Nov 05, 2012 5:06 pm
The later Rev 1 with the 0 ohm resisters and the Rev 2 boards will have the advantage over the Rev 1 boards with polyfuses on the USB. Most of them will draw more than 140 mA under some circumstances. If you have USB polyfuses, butchering them might be an idea if you want the powered hub out of the equation.
by tomexx » Mon Nov 05, 2012 5:44 pm
I think my fuses have 0s stampted on them. Do I have the Rev.2 board hten?
by pluggy » Mon Nov 05, 2012 6:05 pm
The picture is a Rev1 with short circuited polyfuses. The Later Rev ones have black components (zero ohm resisters) instead of the green ones in the picture. The Rev 2 have a single brown component and a hole in that position. It sounds like its a later Rev1 with the 0 ohm resisters. It shouldn't be a problem.
by pluggy » Mon Nov 05, 2012 6:45 pm
A Revision 2 board :
by Onira » Mon Nov 05, 2012 6:58 pm
Well, my Edimax EW-7811un[/] and [i]D-Link DWA-131 freeze/disconnect and they are about 20-30 centimeters from the router...
Cogito ergo sum
by Geesey » Tue Nov 06, 2012 11:35 am
Have you tried disabling power management on the Wifi adaptor?
Onira wrote:Well, my Edimax EW-7811un[/] and [i]D-Link DWA-131 freeze/disconnect and they are about 20-30 centimeters from the router...
by Onira » Sat Nov 10, 2012 10:08 pm
aye
the power management is disabled as it is not supported by this device
Cogito ergo sum
