This is model B board?
by yjdwbj » Mon Nov 05, 2012 7:34 am
Hi, guys. this below message is from my raspberrypi . why the Hardware is not BCM2835. which wrong? My raspberrypi is model B? I'm not sure, because of below message.
# cat /proc/cpuinfo
Processor : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 697.95
Features : swp half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2708
Revision : 000f
Serial : 000000000d2167f2
# free -m
total used free shared buffers cached
Mem: 438 133 305 0 16 89
-/+ buffers/cache: 27 410
Swap: 99 0 99
by jamesh » Mon Nov 05, 2012 8:26 am
Yes, that is a Model B - the 2708 is an internal Broadcom part number for the Silicon itself, but the SOC you have will be the BRCM2835 package.
Volunteer at the Raspberry Pi Foundation, helper at Picademy September, October, November 2014.
by stinos » Mon Nov 05, 2012 10:40 am
sorry to hijack, but: how come that with the exact same cpuinfo, and after all updates etc and with
gpu_mem=64 in the config, I get this for free -m ?
Mem:           184         59        125          0          8         33
-/+ buffers/cache:         17        167
Swap:           99          0         99
by shuckle » Mon Nov 05, 2012 11:36 am
Are you using rasbian ?
You should have
$ uname -a
Linux raspberrypi 3.2.27+ #250 PREEMPT Thu Oct 18 19:03:02 BST 2012 armv6l GNU/Linux
$ sudo /opt/vc/bin/vcgencmd version
Oct 25 2012 16:37:21
Copyright (c) 2012 Broadcom
version 346337 (release)
It really should work if you are on those versions.
$ free -m
Mem:           438         45        392          0          8         22
-/+ buffers/cache:         14        423
Swap:           99          0         99
by stinos » Mon Nov 05, 2012 11:42 am
$ uname -a
$ vcgencmd version
Oct 31 2012 17:57:31
version 347415 (release)
by shuckle » Tue Nov 06, 2012 1:59 pm
What do you have in /boot ?
I missed once fixup.dat and fixup_cd.dat and that caused similar memory problem for me.
by stinos » Tue Nov 06, 2012 6:26 pm
seems fine, I think?
$ l /boot
total 16916
drwxr-xr-x  2 root root   16384 Jan  1  1970 ./
drwxr-xr-x 23 root root    4096 Oct 31 16:51 ../
-rwxr-xr-x  1 root root   17764 Nov  5 11:33 bootcode.bin*
-rwxr-xr-x  1 root root     164 Nov  1 12:09 cmdline.txt*
-rwxr-xr-x  1 root root    1300 Nov  5 17:05 config.txt*
-rwxr-xr-x  1 root root      41 Nov  5 11:33 .firmware_revision*
-rwxr-xr-x  1 root root    2018 Nov  5 11:33 fixup_cd.dat*
-rwxr-xr-x  1 root root    5280 Nov  5 11:33 fixup.dat*
-rwxr-xr-x  1 root root     137 Sep 18 15:40 issue.txt*
-rwxr-xr-x  1 root root 2104952 Nov  5 11:33 kernel_cutdown.img*
-rwxr-xr-x  1 root root 9522048 Nov  5 11:33 kernel_emergency.img*
-rwxr-xr-x  1 root root 2695192 Nov  5 11:33 kernel.img*
-rwxr-xr-x  1 root root  526828 Nov  5 11:33 start_cd.elf*
-rwxr-xr-x  1 root root 2352536 Nov  5 11:33 start.elf*
by shuckle » Wed Nov 07, 2012 7:26 am
Yes, basically looks good, but there are strange small differences in fixup and start file sizes.
My listing:
$ ls -l /boot
total 16872
-rwxr-xr-x 1 root root   17764 Oct 28 19:40 bootcode.bin
-rwxr-xr-x 1 root root     142 Oct 29 00:11 cmdline.txt
-rwxr-xr-x 1 root root    1180 Oct 29 00:11 config.txt
-rwxr-xr-x 1 root root    2020 Oct 28 19:40 fixup_cd.dat
-rwxr-xr-x 1 root root    5282 Oct 28 19:40 fixup.dat
-rwxr-xr-x 1 root root     137 Oct 29 01:01 issue.txt
-rwxr-xr-x 1 root root 2104952 Oct 28 19:40 kernel_cutdown.img
-rwxr-xr-x 1 root root 9522048 Oct 28 19:40 kernel_emergency.img
-rwxr-xr-x 1 root root 2695192 Oct 28 19:40 kernel.img
-rwxr-xr-x 1 root root  523144 Oct 28 19:40 start_cd.elf
-rwxr-xr-x 1 root root 2347828 Oct 28 19:40 start.elf
If you really have the latest firmware and kernel, I would try downloading the bootloader files and copy those over the current ones (after taking a backup of the SD card):
$ cd test-directory
$ sudo apt-get download raspberrypi-bootloader
$ sudo dpkg --extract raspberrypi-bootloader_1.20121025-1_armhf.deb testboot
After I would copy those files that are different into the boot folder.
by stinos » Fri Nov 09, 2012 8:10 am
thanks, but following this thread viewtopic.php?f=26&t=22199 it seems that I simply have the 256mb version so it's gonna be pretty hard to squeeze 5120mb out of that :D
