Suitable voltage variation for switching mode power supplies
by Siegfried » Mon Nov 05, 2012 1:12 am
Hello folks,
New user here. This question may be somewhat off-topic, but I failed to find out a better forum to post it. Also, I could not find another topic about this (but I think it already exists).
What is the normal/acceptable voltage variation for a good switching mode power supply under a given load? I'm using a Kindle 3 charger as power supply for my RPi and, before trying to switch to a Chinese no-brand 1A source, I though it was a good idea to check the voltage output in a workbench. All measures were taken with a simple multimeter, I have no oscilloscope to check for the ripple and other AC noise.
A Kindle charger (rated 5V, 850mA max) with no load measured 4,9V. When powering some resistors and LEDs totaling a load of 85mA, output voltage dropped to 4,84V.
One no-brand supply (rated 5V, 1A) gave 5,14V with no load and 4,94V under 85mA. Another one (rated 5,2V 1,5A) gave 5,5V with no load and 4,87V with 85mA.
I will continue to use the Kindle charger for my RPi but I', really curious about the reliability of such products. What is the normally accepted variation for these off-the-shelf power sources?
by Dilligaf » Mon Nov 05, 2012 3:44 am
You need to check the voltage from TP1 to TP2 on the Pi while running under full load to know if your power supply is acceptable, ideally you want 4.85+ volts.
