Is it possible for a few posts to stay editable?
by Gabriel » Thu Jun 21, 2012 12:08 pm
Everything is in the title :p
Yes, I'have read faq.php#f2r1 and I understand that it's needed on such a big forum but I was wondering for the people who have a project and would like to keep the first post up to date...
in example : I would like to edit the two first post of this thread : viewtopic.php?f=35&t=7739
Thank you for reading :)
edit : I don't like my title :oops: it's more like "Is it possible for a few posts to stay editable?"
My home-made case : http://goo.gl/nprcI ; My presentation http://goo.gl/5hSar et en français : http://goo.gl/28Vif ; Please think to the FAQ and to the Wiki
by AndrewS » Thu Jun 21, 2012 12:21 pm
In that case, maybe a wiki or blog would be more appropriate?
by Joe Schmoe » Thu Jun 21, 2012 12:28 pm
The problem is that your original post won't come up as "new" (i.e., "unread") for people, so the net result is that no one will read your updates. That basic to the way forums are designed to be used.
Faced with the choice between changing one's mind and proving that there is
no need to do so, almost everyone gets busy on the proof.
- John Kenneth Galbraith -
by jamesh » Thu Jun 21, 2012 1:30 pm
Yes, a blog or Wiki entry woudl be more appropraite I think. Then on the forum thread just post a link to your latest blog/Wiki update.
Volunteer at the Raspberry Pi Foundation, helper at Picademy September, October, November 2014.
by Gabriel » Fri Jun 22, 2012 10:40 am
Ok, thank you for your answers, I had'nt thought about the problem of the "already read" function !
Joe Schmoe wrote:The problem is that your original post won't come up as "new" (i.e., "unread") for people, so the net result is that no one will read your updates. That basic to the way forums are designed to be used.
I will try to find a wiki and/or a git.
by AndrewS » Fri Jun 22, 2012 10:45 am
http://rpi-developers.com/ might be ideally suited? 8-)
by RaTTuS » Fri Jun 22, 2012 10:47 am
http://www.catb.org/esr/faqs/smart-questions.html Ask Questions
http://www.raspberrypi.org/forums/viewtopic.php?f=29&t=7192 AutoStart Script
"That's not right, the badgers have moved the goalposts."
by bonelifer » Fri Jun 22, 2012 6:27 pm
phpBB has a Bump setting: You can only bump a topic if you are the author or the last poster. A topic that is bumped will appear as unread topic for all members.
Bumping in phpBB is a Forum permission which needs to be set per forum per usergroup/user.
Note that in ACP - GENERAL - Post settings you should set the "Bump interval".
Another thing that would be nice if they set it up.
Location: http://www.phpbb.com/community/memberlist.php?mode=viewprofile&u=147848
by Gabriel » Sat Jun 23, 2012 5:39 pm
AndrewS wrote:http://rpi-developers.com/ might be ideally suited? 8-)
RaTTuS wrote:http://elinux.org/R-Pi_Hub
Great ! Thanks for the links !
by mahjongg » Sat Jun 23, 2012 5:54 pm
Gabriel wrote: I don't like my title :oops: it's more like "Is it possible for a few posts to stay editable?"
Changed that for you. :lol:
by Gabriel » Sat Jun 30, 2012 8:49 am
thanks ;)
